SOLVED - VNC
Posted: Sun Oct 16, 2016 3:40 pm
by ex_directory
When starting VNC via "sudo raspi-config", i can see it calls some scripts. How can i see what these are?
I want to add them to rc.local so VNC server is started after every reboot.
Re: VNC
Posted: Sun Oct 16, 2016 4:03 pm
by B.Goode
The command line version of raspi-config is simply a shell script so you can examine its contents with a text editor or viewer.
(But isn't the point of raspi-config that you configure the future behaviour of the system?)
Re: VNC
Posted: Sun Oct 16, 2016 4:33 pm
by ex_directory
But when i enable the vnc through the raspi-config, it does not restart the server on next reboot.
Am I missing something?
Re: VNC
Posted: Sun Oct 16, 2016 4:39 pm
by FTrevorGowen
ex_directory wrote:But when i enable the vnc through the raspi-config, it does not restart the server on next reboot.
Are you referring to the activation of the RealVNC server provided in the current release of Raspbian Jessie Pixel? If so have you updated/upgraded recently too? (IIRC, in another thread, there was a similar issue which has now been fixed - associated with one of the RealVNC startup scripts, which has/have been updated)
Trev.
SOLVED - Re: VNC
Posted: Sun Oct 16, 2016 6:05 pm
by ex_directory
Thanks, that was it. Just had to update.
Now starting on each reboot.
