anujd9
How to do serial communication on Raspberry pi 3 using putty
Mon Oct 03, 2016 7:30 pm
Hi. On windows, I have a project in which I communicate with a nordic bluetooth dongle using serial communication over putty. I want to port the project to Raspberry Pi.
Now, I have putty installed on Raspberry Pi 3. I just want to verify that to communicate with the dongle using serial communication, I need to use the USB to serial TTL wire and connect the dongle to that USB and the wires to serial ports of Raspberry pi 3 and then access the serial port using putty and the name of com port being used. Is this method correct ??
enik1
Re: How to do serial communication on Raspberry pi 3 using p
Wed Oct 05, 2016 10:46 am
As far as I know Putty is an SSH client working over Internet. It is not built for serial communication.
Enik
AWT and Swing developer
pcmanbob
Wed Oct 05, 2016 12:00 pm
Putty can be used for serial comms.
just select serial , then the comport you want to use and comms speed the speed.
mutley
Wed Oct 05, 2016 2:03 pm
I don't think you even need putty for what you are trying to do on a linux box. Simply look at the output of /dev/ttyUSB0 (or 1) to read what's being sent.
sudo tail -f /dev/ttyUSB0
That will print the output directly to the terminal, you can write in exactly the same way with echo "bla bla bla" > /dev/ttyUSB0. Exactly what you would need putty for on a Windows box. Only problem with this method is you can't set the baud / stop / data bits. Only way I know how to do that is with a programming language, not the native shell.
As for connecting the device, I don't know anything about it, (so this is a guess). But I doubt you would need to connect it to the USB port and the GPIO tx/rx pins. Plug it in, look in the system logs and see what the pi recognizes it as. My bet is you'll get a /dev/ttyUSB0/1 device and you can use that for communication
daveake
Wed Oct 05, 2016 9:34 pm
stty is the command to configure serial ports.
CarlRJ
Wed Oct 05, 2016 10:07 pm
If the Bluetooth dongle you're talking about is something like this: Nordic nRF51 Dongle (first Google hit), that plugs in to USB, there's no need to connect it to the Pi's serial I/O pins. Just plug it into a USB port on the Pi.
I have an app that reads "serial" data from an Arduino that's plugged into a USB port on the Pi, using a library called PySerial that should already be on your Pi. Reading and printing data is as easy as this:
#!/usr/bin/env python3
import serial
port = '/dev/ttyACM0'
bps  = 57600
ser = serial.Serial(port, bps)
while True:
    line = ser.readline()                 # read bytes until line-ending
    line = line.decode(encoding='UTF-8')  # convert to string
    line = line.rstrip('\r\n')            # remove line-ending characters
    print(line)
You could likely start from there (copy into a file called, say, "usbcat", then "chmod 755 usbcat", and then run it with "./usbcat" and stop it with control-C), change the port and speed to meet your needs (the setup call to Serial can take all sorts of other parameters as needed), and have a bit of code that you can expand to do whatever you want with the device.
