awneil
RPi 3 Bluetooth LE - bluetoothctl missing commands
Thu Sep 29, 2016 12:57 pm
I have the latest Raspbian Jessie image: 2016-09-23-raspbian-jessie.img
I have been able to do basics like scan for & connect to BLE devices.
This blog post: https://acassis.wordpress.com/2016/06/
says that “gatttool” is deprecated and will be removed soon, then we need to use bluetoothctl instead.
I can, indeed, use bluetoothctl - but some of the mentioned commands are missing!
eg, 'list-attributes' and 'attribute-info' are both used in that blog, but both just return "Invalid command" on my Pi.
Are they just not available on the Pi?
Or what do I need to do to get them?
dpkg -s bluez gives the following:
Package: bluez
Status: install ok installed
Priority: optional
Section: admin
Installed-Size: 2588
Maintainer: Debian Bluetooth Maintainers <[email protected]>
Architecture: armhf
Multi-Arch: foreign
Version: 5.23-2+rpi2
Replaces: bluez-audio (<= 3.36-3), bluez-input, bluez-network, bluez-serial, bluez-utils (<= 3.36-3), udev (<< 170-1)
Depends: libc6 (>= 2.15), libdbus-1-3 (>= 1.1.1), libglib2.0-0 (>= 2.28.0), libreadline6 (>= 6.0), libudev1 (>= 196), init-system-helpers (>= 1.18~), kmod, udev (>= 170-1), lsb-base, dbus
Breaks: udev (<< 170-1)
Conflicts: bluez-audio (<= 3.36-3), bluez-utils (<= 3.36-3)
Conffiles:
 /etc/bluetooth/input.conf 9f85017f861ac34d983fa76fa715f9c3
 /etc/bluetooth/main.conf 297ad1bff9ec02f760eb6b5b7bf48e74
 /etc/bluetooth/network.conf 0c7497c405b963382ff71789d0730abd
 /etc/bluetooth/proximity.conf b75823a140e00905d41465c380bf89fe
 /etc/dbus-1/system.d/bluetooth.conf 98bb1c2cf393ac16f0ba3bb0153a4f30
 /etc/default/bluetooth 1e25cf981f29147187311b94f8e0ea89
 /etc/init.d/bluetooth 1d503f26c72a83c43b90422ec5907626
Description: Bluetooth tools and daemons
 This package contains tools and system daemons for using Bluetooth devices.
 BlueZ is the official Linux Bluetooth protocol stack. It is an Open Source
 project distributed under GNU General Public License (GPL).
Homepage: http://www.bluez.org
_RobP
Re: RPi 3 Bluetooth LE - bluetoothctl missing commands
Thu Sep 29, 2016 1:31 pm
If you notice the context that the blog is in changes after the author connects to the bluetooth device:
[CHG] Device EC:F2:E5:CE:30:5B Connected: yes
Connection successful
//get information from device
[Nordic_UART]# info
I haven't seen this happen in my experience with bluetoothctl. I have to type info <MAC_ADDRESS> to return the connected devices information.
I haven't got a solution for you, but it could explain why you're seeing the error you're getting.
awneil
Thu Sep 29, 2016 1:50 pm
Cheers.
Yes, I did notice that.
But the commands on my RPi seem to be completely missing - not just taking (slightly) different parameters?
This guy seems to have a similar observation about the "missing" commands: http://stackoverflow.com/a/34284055/4618900
His explanation is rather sketchy - looks like Bluez has to be (re-?) installed with some "experimental" option(s)? Plus some other configuration tweaks?
awneil
Thu Sep 29, 2016 2:09 pm
Douglas6
Thu Sep 29, 2016 2:16 pm
The author of that blog is using BlueZ 5.40. Raspbian Jessie comes with BlueZ 5.23. So you'll either need to build a newer version of BlueZ, or stick with gatttool.
awneil
Thu Sep 29, 2016 2:40 pm
OK - thanks.
So, to update BlueZ, would I have to uninstall the existing version first? If so, how would I do that?
Or would just building the newer version automatically update/overwrite the existing one?
Douglas6
Thu Sep 29, 2016 2:53 pm
I haven't tried it myself in Jessie. My instinct would be to not uninstall BlueZ first, but let/make the new version replace the old. I haven't seen a guide for that, so if you're successful, please share your steps.
leoliuhui25
Fri Jan 12, 2018 6:44 am
I am using bluez Version 5.48.
From help command you will find there is a Submenu,
# help
Menu main:
Available commands:
advertise Advertise Options Submenu
scan Scan Options Submenu
gatt Generic Attribute Submenu
list List available controllers
show [ctrl] Controller information
select <ctrl> Select default controller
Then you can enter the gatt Submenu via command:
#menu gatt
You can use the missing commands now.
awneil
Fri Jan 12, 2018 10:40 am
leoliuhui25 wrote: I am using bluez Version 5.48.
Well, I guess things have moved on since the last post in this thread - Sep 2016.
So what version of Raspbian are you using :?:
Did this version of BlueZ come with that version of Raspbian - or did you have to manually install or update it?
