viewtopic.php?p=1046687#p1046687aworan wrote:Is the source code will be publish by the RPF ?kusti8 wrote: It's an issue with the API keys that got overloaded and disabled. A new release is coming soon.
Thank you
Re: RPF Chromium Browser "sign into chromium" not working
There are 10 types of people: those who understand binary and those who don't.
Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.
Thanks and thankks again the Google Account Synchronization is FIXEDkusti8 wrote:Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.
fruitoftheloom wrote:Thanks and thankks again the Google Account Synchronization is FIXEDkusti8 wrote:Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.![]()
Wait how did you apply this patch already? Has the update already been released, cause I just updated chromium on my raspberry pi 3 model B and it still won't let me sign in and sync?
Re: RPF Chromium Browser "sign into chromium" (SOLVED)
Sync is working for me again as well
Did you do2mandude wrote:fruitoftheloom wrote:Thanks and thankks again the Google Account Synchronization is FIXEDkusti8 wrote:Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.![]()
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgade
Thank you so much for all your effort kusti8! It is working fine for me now. Just out of curiosity what is widevine?kusti8 wrote:Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.
widewine libs for drm websites like Netflix.Malman35 wrote: Thank you so much for all your effort kusti8! It is working fine for me now. Just out of curiosity what is widevine?
Ah OK. Thanks.cjan wrote:widewine libs for drm websites like Netflix.Malman35 wrote: Thank you so much for all your effort kusti8! It is working fine for me now. Just out of curiosity what is widevine?
I just finished running all of those commands, but chromium-browser is still telling me "Service unavailable"Malman35 wrote:Did you do2mandude wrote:fruitoftheloom wrote: Thanks and thankks again the Google Account Synchronization is FIXED![]()
Wait how did you apply this patch already? Has the update already been released, cause I just updated chromium on my raspberry pi 3 model B and it still won't let me sign in and sync?Code: Select all
sudo apt-get update sudo apt-get upgrade sudo apt-get dist-upgade
Just a suggestion but you could try uninstalling then reinstalling it and see if that helps. Anybody else have a better suggestion?2mandude wrote: I just finished running all of those commands, but chromium-browser is still telling me "Service unavailable"
What version of Chromium Browser ???2mandude wrote: I just finished running all of those commands, but chromium-browser is still telling me "Service unavailable"
I really appreciate the help, thanks so much guys. Hopefully, I can get it to work soon. I'm gonna try to reinstall right now, and right now im on chromium 51.0.2704.106
Edit: Darn, still no luck..
51.0.2704.91-0ubuntu0.14.04.1.7012 is the version listed in Synaptic Package Manager as latest from RPF, I am running Jessie with Pixel fully updated on a RPi ZERO.2mandude wrote:I really appreciate the help, thanks so much guys. Hopefully, I can get it to work soon. I'm gonna try to reinstall right now, and right now im on chromium 51.0.2704.106
Thanks a lott for fixing the "Sign in issue"!!!!fruitoftheloom wrote:Thanks and thankks again the Google Account Synchronization is FIXEDkusti8 wrote:Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.![]()
Can confirm it works here as well. I had to uninstall chromium first, and then update. Working great, thanks!
Kratos
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
Nope, still no joy.
After fully updating/upgrading/dist-upgrade uninstalling/purging and reinstalling chromium-browser, I still getting the "Uh-Oh...service unavailable" message.
Am I missing anything?
Have you got Chromium Browser version ""51.0.2704.91-0ubuntu0.14.04.1.7012"" ??rmettier wrote:Nope, still no joy.
How did you find that version? I checked synaptic package manager as you mentioned earlier, and I'm still getting this chromium version: 51.0.2704.106.
Is there another way to access the older one that you have, because this latest one doesn't let me sign in. Or maybe I didn't install synaptic correctly? idk.. im pretty new to the pi
2mandude wrote:How did you find that version? I checked synaptic package manager as you mentioned earlier, and I'm still getting this chromium version: 51.0.2704.106.
sudo nano /etc/apt/sources.list
sudo apt-get update
sudo apt-get purge chromium-browser
sudo apt-get install chromium-browser
The bit about removing the Ubuntu related source entry finally did it. Works now with the version you mentioned.
Thanks for your work and the great support.
I'm also new to Raspberry Pi. I followed the directions above and it keeps re-installing Chromium 51.0.2704.91
when I enter this code in:
I get this:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free r$
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://dl.bintray.com/kusti8/chromium-rpi jessie main
Nothing about Ubuntu sources. What am I doing wrong?
Thanks for the help
Thanks for the help
That's correct. That's the version you should be on. No problems there.
Thanks for replying.
So, if that's all set. When I run:
sudo apt-get update
sudo apt-get purge chromium-browser -y
It installs the same version of Chromium (51.0.2704.91). Anything else I'm missing?
I actually did this yesterday and got it to work. Then, today I messed up my video settings, so I re-formatted my SD and re-installed NOOBS. Now, I can't seem to get it to install the newer Chromium version
thanks again
sudo apt-get update
thanks again
That is the newer version of chromium. There is absolutely no problems with that version and it is the latest. Any reason you're working about that?
It works.
I kept getting "service unavailable" yesterday, but I wonder if that was from the internet outages yesterday. Works great now.
Thanks for helping
Thanks for helping
