joan
Re: pigpio - request for testers
Sun Sep 25, 2016 11:45 am
@fivdi
Your Pi shows the problem when you use dtparam=audio=on.
That setting has no effect on my Pi3B (144000 still reported).
It does suggest a possibility which I will now try out.
Sun Sep 25, 2016 11:59 am
Next test on my 3B with this config.txt
get_clocks before
[email protected]:~/c# ./get_clocks
GP0: src=0 divi=0    divf=0    freq=0.000   Hz
GP1: src=6 divi=20   divf=0    freq=25.000  MHz
GP2: src=1 divi=600  divf=0    freq=32.000  kHz
PCM: src=0 divi=0    divf=0    freq=0.000   Hz
PWM: src=0 divi=0    divf=0    freq=0.000   Hz
[email protected]:/tmp# ./f160849.sh
144000 pigpio-log
143988 pigpio-log
get_clocks after
PCM: src=6 divi=250  divf=0    freq=2.000   MHz
PWM: src=6 divi=50   divf=0    freq=10.000  MHz
After a reboot with just
dtparam=audio=on
in /boot/config.txt
Before
PWM: src=6 divi=5    divf=0    freq=100.000 MHz
127512 pigpio-log
127524 pigpio-log
After
joan
Sun Sep 25, 2016 12:23 pm
I've tried dozens of combinations of config.txt. Still can't get it to fail. I even cut&paste dtparam=audio=on into my config.txt to see if I typed it wrong.
My Pi3B is an up to date jessie (well it was a few days ago) with 4.4.21-v7+ #911 SMP.
processor	: 3
model name	: ARMv7 Processor rev 4 (v7l)
BogoMIPS	: 38.40
Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd03
CPU revision	: 4
Hardware	: BCM2709
Revision	: a02082
Serial		: 00000000bb786d6b
dgordon42
Sun Sep 25, 2016 12:32 pm
Try running a sound command, and it will fail afterwards, like this:
Last login: Sun Sep 25 12:10:16 2016
[email protected] ~ $ cd joans_test/
[email protected] ~/joans_test $ sudo ./get_clocks
[email protected] ~/joans_test $ sudo pigpiod
[email protected] ~/joans_test $ ./testing.sh
144000 pigpio-log
[email protected] ~/joans_test $ cd ../python_games
[email protected] ~/python_games $ aplay match1.wav
Playing WAVE 'match1.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Mono
[email protected] ~/python_games $ cd ../joans_test
7032 pigpio-log
Playing a sound seems to change the PWM clock from 10MHz to 100MHz, and the test fails.
The 'booting with a HMDI monitor plugged in ' thing stops this from happening if the sound is played through the monitor. This is not the case with all monitors.
Hope this helps,
Dave.
joan
Sun Sep 25, 2016 12:36 pm
@Dave
Yes, playing audio will cause a problem. The test is expected to fail if audio has been played (after the pigpio daemon has been started). It shouldn't fail if audio hasn't been played.
fivdi
Sun Sep 25, 2016 12:47 pm
@joan are you testing with pigpio V50? The is the version that was released with Raspbial Jessie in May.
I'm using pigpio V50 and
Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
joan
Sun Sep 25, 2016 1:19 pm
fivdi wrote:@joan are you testing with pigpio V50? The is the version that was released with Raspbial Jessie in May.
I'm using V56.
The initial report I had was for V55.
JimmyN
Sun Sep 25, 2016 1:38 pm
I tried it on a RPi1B+, that uses the RPF 7" display and it failed as well, both with HDMI plugged in and without.
So I went and looked at config.txt on the B+ and found this entry
# Enable audio (added by raspberrypi-sys-mods)
dtparam=audio=on
I commented the line out, rebooted and then ran the script again and got "144000" this time, both with and without HDMI.
I then went to the RPi3 and checked config.txt and had the same "dtparam=audio=on" line so I commented that out, rebooted, and then got the expected "144000" on the RPi3, again both with and without HDMI. I guess audio was turned on after all, and running a desktop was producing some audio (mouse clicks and such), but I didn't realize or think about it since I have no speakers attached. So both the B+ and the RPi3B running desktops failed with audio turned on, and both pass with audio turned off.
Sun Sep 25, 2016 2:51 pm
Ah, my 3B with the RPF screen boots to the GUI. I've no idea if it makes sounds because there's no audio device attached to it.
ChristophK
Mon Oct 17, 2016 1:15 pm
I use a HDMI to DVI cable with Raspi3 and in /boot/config.txt "dtparam=audio=on"
126???
with that line disabled it changed to
# dtparam=audio=on
[email protected]:~/Desktop $ ./pigpiotest.sh
144000 pigpio-log
[email protected]:~/PIGPIO $ sudo ./get_clocks
Another strange behavior is a changing SPI baudrate. With 100 kHz spi_open ist starts with about 160 kHz (measured on a scope) and after some seconds changes to the correct value.
with audio disabled this also did not happen again.
