Page 1 of 2
Pi3 with a lightning bolt?
Posted: Tue Sep 13, 2016 2:08 am
by Doug B
When I started my Pi3 just now, I got a picture of a lightning bolt in the upper right corner of the screen. Could someone please tell me what that means?
Doug Byfield
Re: Pi3 with a lightning bolt?
Posted: Tue Sep 13, 2016 7:29 am
by RaTTuS
can you post a picture
Posted: Tue Sep 13, 2016 9:57 am
by 6by9
https://github.com/raspberrypi/firmware ... 52c4a6be83
firmware: arm_display: Add bitmapped icons for warning conditions
See: #367
It would have helped if you'd said you'd done an rpi-update (not recommended these days unless you need the absolute bleeding edge developments and are prepared for the occasional breakage)
Posted: Tue Sep 13, 2016 10:08 am
by RaTTuS
aha so power brownout
Posted: Tue Sep 13, 2016 10:19 am
by 6by9
RaTTuS wrote:aha so power brownout
Probably, although I haven't done an rpi-update and looked myself, and the commit doesn't say.
It would be the most logical one out of under-voltage and over-temp (yellow or red).
Posted: Tue Sep 13, 2016 6:58 pm
by douglasby
Thanks, 6x9, that link is quite useful.
Now that I think of it, I **DID** do a rpi-update on Raspian full version. I didn't know that it wasn't recommended.
BTW-the lightning bolt went away after 2-3 reboots. I was also using a RAV Power Pack battery:
https://www.modmypi.com/raspberry-pi/ac ... ?limit=100
6by9 wrote:https://github.com/raspberrypi/firmware ... 52c4a6be83
See: #367
Posted: Thu Dec 08, 2016 11:45 pm
by cliveflint
I just had some Anker cables delivered and the lightning symbol has disappeared.
Good quality cables make a difference.
Posted: Fri Dec 09, 2016 1:38 am
by Douglas6
cliveflint wrote:Good quality cables make a difference.
Er, yes. There must be thousands of posts on this board to that effect.
Posted: Sun Feb 12, 2017 11:41 am
by darksky
I too see this for maybe 2-3 seconds when my RPi2 boots only. Could it be a false positive triggered by something in the boot process? I used stress to max out all CPUs (temp got up to 60C), yet I didn't see this icon again.
stress --cpu 20 --io 20 --vm 6 --vm-bytes 25M --timeout 120s
Posted: Sun Feb 12, 2017 1:06 pm
by mahjongg
darksky wrote:I too see this for maybe 2-3 seconds when my RPi2 boots only. Could it be a false positive triggered by something in the boot process? I used stress to max out all CPUs (temp got up to 80C), yet I didn't see this icon again.
no, its not a false trigger, the hardware simply detects a brownout at that point (where the GPU, not the CPU, is stressed fully for a short time). Just get a better micro USB cable if you want to keep safe, or simply ignore the problem at your own risk.
Posted: Sun Feb 12, 2017 2:07 pm
by darksky
Thanks for the info. I have tried playing back videos where the GPU would be doing the decoding and cannot reproduce :/ Is there an artificial GPU stress I can run to see about replicating?
Posted: Sun Feb 12, 2017 2:14 pm
by FTrevorGowen
+1
Also note that @douglasby was using a powerbank - some can take a few seconds to settle down after the initial current surge during boot. (Something I observed when the low-voltage detection/warning system was introduced with the B+)
Trev.
Posted: Wed Feb 15, 2017 2:35 am
by Texas-Mark
darksky wrote:I too see this for maybe 2-3 seconds when my RPi2 boots only. Could it be a false positive triggered by something in the boot process? I used stress to max out all CPUs (temp got up to 60C), yet I didn't see this icon again.
I see the same thing ONLY when the Pi is booting up. It happens even when booting just the PI with nothing attached. If I run it normally with a breakout cable and several sensors and even 3 backlit LCDs and a servo, I never get the symbol after boot (and I don't have it disabled either). I tried several power supplies including a 5.1V (adjustable) 4A one and I use the recommended Mediabridge cable (and have tried others), but it still comes up for a couple of seconds during boot. I just ignore it because I know there is nothing wrong with the power supply or cable. But still I am curious as to why it displays. I'm pretty sure it did not start doing it until a relatively recent Raspian update. I need to dig out my scope and take a look at the 5V line and see if it's doing anything when the symbol appears.
Edit - Got out my pocket scope and watched the 5V line (on the Pi) during boot up and it never dipped more than a few millivolts.
Posted: Fri Feb 17, 2017 3:37 pm
by krisvale
I get this lightning bolt for a few seconds, once in a while.
The rpi2 is just sitting idle. Sometimes even with the display blacked out.
This really seems to be a false positive, I wonder if it is disableable?
Posted: Fri Feb 17, 2017 3:44 pm
by jamesh
krisvale wrote:I get this lightning bolt for a few seconds, once in a while.
No, its not a false positive, but even when idle the Pi might be doing something (e.g. talking to a USB device) that increases power consumption slightly.
Posted: Fri Feb 17, 2017 3:46 pm
by jamesh
When it first starts up , the power requirements are a bit higher - all cores running at full tilt until governor kicks in (IIRC), all attached devices being started up etc. Might be enough to ping the detection.
Posted: Tue Feb 28, 2017 7:09 pm
by spoz
I have the same issue, I get the lightning bolt symbol quite often on boot.
I have checked my power supply and it reads 5.21v the entire time, an the pi never draws more than 0.5A. I havent checked the ripple with an oscilloscope but I am using two good quality USB supplies and 0.5A is well within their spec (1A and 2A).
Considering the intended use/users, I consider it a design fault for there not to be any voltage regulation onboard. If short duration load spikes are such a common issue, how hard is it to add an input capacitor?
Posted: Tue Feb 28, 2017 7:27 pm
by texy
where are you measuring the voltage? On the Pi itself? That's where you'll need to measure it.
Texy
Posted: Tue Feb 28, 2017 8:15 pm
by spoz
You are totally right. In between now and my last post I discovered the test points on the pi and did some probing. Turns out all of my USB cables are dropping 150-180mV. Though the input stage of the pi (current mirror and fuse) drops nearly 60mV.
Edit: So after the input stage at TP7, I am still getting 5.00v, and seeing the lightning bolt icon. Must be transients too fast for my meter.
Time to buy some shorter cables, or maybe make my own with some large gauge wire.
Thanks for the point in the right direction.
Posted: Wed Jun 21, 2017 11:09 am
by i-Moi
Hi everybody, I had the same problem myself, and I finally solved it by using a better and shorter cable. The lightning bolt symbol disappeared. Unfortunately, no temperature symbol has appeared, because the cable is so short it's too close to my other devices in a pretty little space, and therefore, temperature has risen up... does anyone has an idea about longer but still good quality cables ? Thanks !
Posted: Wed Jun 21, 2017 5:45 pm
by mahjongg
No temperature symbol is good, it means your device is NOT overheating, I doubt it can overheat from a nearby cable as these certainly should not get hot.
Posted: Wed Jun 21, 2017 6:48 pm
by rpdom
Should that read "Unfortunately, now temperature symbol has appeared"?
Posted: Thu Jul 20, 2017 8:33 pm
by Sioghi
I'm having this issue using the official 7" touch display on my Pi3.
Powersupply delivers 2.4A, tried new shorter and thicker cables and different PSUs, without any improvement.
I did run upgrades. The lightning bolt is always there even when CPU is idle.
I havent tried a plain installation yet as it requires disassembly to access the sdcard. Poor design or the official touchscreen housing imo. Furthermore I had to rotate the display because of the manufacturing flaw.
Any advice is welcome.
Best regards
Posted: Fri Jul 21, 2017 6:55 am
by jamesh
Hmm. I don't see that issue with similar setup. Might be worth starting a new thread in the display section.
Posted: Fri Jul 21, 2017 7:32 am
by davidcoton
My touchscreen and B+ combo needs two cables and a supply with dual output to avoid undervoltage issues.
