Pi for battery monitor with low voltage switch
Posted: Tue Aug 23, 2016 10:20 pm
Hi, I have several model Pi's available to me to use and wish to look at using one of them as a 12v battery monitor/charger control.
What I want to do is to be able to monitor the battery voltage and when it drops to a predefined level have the Pi be able to turn on an external relay for a pre-defined period of time, but I also want to be able to log the event, containing time/date that the event occurred.
Some details for this project.
Currently I have an external intelligent charger, so 7 level charging down to float and monitoring that turns on 3 times a week using a time clock to charge the bank, but seeing as the equipment attached is not always on and drawing power it does not always need this amount of charging, it could possibly go for a couple of weeks without any charging, so I am trying to minimize the amount of grid power draw from the charger.
If anyone know of a project similar to this that has already been done I would appreciate any help to point me in the right direction.
Regards
Ian
Regards
Ian
