kiranmadansar
Not running a script
Wed Aug 17, 2016 9:50 am
I have two python scripts.
1) reads the data from SQLite database
2) writes to database using a threading module and queue
I have put these in the rc.local and are executing fine on reboot. But, if I unplug the power suddenly and re-plug it, only reading script is executing. Is it because of the thread and queue (both are not terminating properly due to power off) that i'm using?
fireraisr
Re: Not running a script
Wed Aug 17, 2016 7:44 pm
I try to avoid using rc.local for boot scripts. Once upon a time I used them exclusively, then I learned cron and life was better.
Try moving your scripts to /home/pi and adding the following line to crontab (type "crontab -e" to get to the editor and see my sources below for a more in depth tutorial).
@reboot  python /home/pi/read.py &
@reboot  python /home/pi/write.py &
sources: http://www.cyberciti.biz/faq/linux-exec ... em-reboot/
http://www.raspberrypi-spy.co.uk/2013/0 ... sing-cron/
Thu Aug 18, 2016 12:00 am
Better than crontab -e is /etc/cron.d/somefilenamehere create a unique file in that directory for each thing you want cron to launch.
thagrol
Thu Aug 18, 2016 6:12 pm
Try changing the startup command (regardless of whether it's in rc.local, crontab, etc) to something like this:
/path/to/writer.py >/tmp/writer.log 2>&1 &
This should capture any output and error messages in /tmp/writer.log.
