Guneish
Setting up DDNS on Pi
Sun Aug 14, 2016 8:32 am
Hello, how do I go about setting up DDNS on the Raspberry Pi from the terminal on a Macbook using a DDNS service from www.dyndns.com? Thank you and I appreciate any help. :)
pcmanbob
Re: Setting up DDNS on Pi
Sun Aug 14, 2016 10:15 am
If you mean the updater client.
then you need to follow the install instructions here
https://help.dyn.com/update-clients/
you need the linux version of course but I am not sure it supports command line install and set up, only desktop install and setup.
DuckDNS
Sat Oct 08, 2016 9:47 pm
Hi Guneish,
have you considered DuckDNS, we run a completely free DDNS service that you can script/cron on your PI, we have several login methods Google+, Reddit, Facebook, Twitter (using oAuth).
The setup instructions on Pi can be found here: https://www.duckdns.org/install.jsp?tab=pi
QUACK!
castletonroad
Sun Oct 09, 2016 2:42 am
DuckDNS wrote:Hi Guneish,
QUACK!
Maybe you should stop SPAMMING every post on DDNS with your advertising..? (C'mon Mods...)
Raspberry Pi 3 Model B | Raspberry Pi 2 Model B
MikeDunn
Sun Oct 09, 2016 9:32 am
A bit unfair there, perhaps ?
A look at DuckDNS's stats reveals
Last visited: Sat Oct 08, 2016 10:15 pm
5 posts in over 3 years ? Hardly spamming ...
Sun Oct 09, 2016 9:41 am
MikeDunn wrote:A bit unfair there, perhaps ?
Actually 1 post 3 years ago and 4 posts 8th October 2016, yes that is a bit OTT :?
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
