I just received MS VC-1 key from Raspberry Pi. But I found that it can only play the WMV file with Codec ID: WVC1 and WMV3 is not working at all. According to Wikipedia, WMV3 is also a part of VC-1, any idea of this issue?
Here is the non-working WMV information:
Format : VC-1
Format profile : MP@HL
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Duration : 38mn 14s
Bit rate mode : Constant
Bit rate : 4 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 fps
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.072
Stream size : 1.07 GiB (95%)
Working WMV information:
Format : VC-1
Format profile : Advanced@L2
Codec ID : WVC1
Codec ID/Hint : Microsoft
Description of the codec : VC-1 - VC-1 Advanced Profile
Duration : 1h 48mn
Height : 720 pixels
Frame rate : 29.970 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.145
Stream size : 3.03 GiB (98%)
