Raspberry Pi for children/students/beginners?
Posted: Sun Aug 26, 2012 10:45 am
I am completely new to Raspberry Pi. I have ordered one and I am hoping that I will learn a lot about computing and programming with it. I heard it was aimed at getting children and students back into enjoying computer science and programming. As a 35 year old with little experience of any of that I thought that the Raspberry Pi would be a good place to start. However, just looking at the FAQ on the Raspian website I am already confused...
Raspbian is an unofficial port of Debian Wheezy armhf with compilation settings adjusted to produce optimized "hard float" code that will run on the Raspberry Pi. This should provide significantly faster performance for applications that make heavy use of floating point arithmetic operations.
The port is necessary because the official Debian Wheezy armhf release is compatible only with versions of the ARM architecture later than the one used on the Raspberry Pi (ARMv7-A CPUs and higher, vs the Raspberry Pi's ARMv6 CPU).
Should I understand all of this? Do children understand this? Is there a glossary somewhere? A complete beginner's guide I can purchase or download? Should I give up now and go back to reading Janet and John?
Thanks for any advice you can give me.
Matt
Matt
