Hello all,
I am needing to find out who manufactured my Pi. I do believe i have run by the process once before, but I don't remember how i did. I tried 'cat /proc/cpuinfo' , and it doesn't tell me who manufactured it. please help. Thanks to all whom help!!
How Do I Find Out Who Manufactured My Pi??
Pi3B, Raspbian Jessie
- DougieLawson
- Contact: Website Twitter
Re: How Do I Find Out Who Manufactured My Pi??
cat /proc/cpuinfo does tell you, but it's encoded in the "Revision" field.
@DougieLawson, Ahh, I see. So I did some research on this, and it turns out that the revision indicates that the manufacturer is unknown. It's very odd.The other revision codes on the list I found online show for Sony, and a couple other known manufacturers.
- HermannSW
- Contact: Website Twitter YouTube
Kolban's book on Raspberry Pi has full details, you just need 2 digit of BCM revision, in case of my Zero its Sony:
900093
Manufacturer:
0x00 – Sony
0x01 – Egoman
0x02 – Embest
0x03 – Not used
0x04 – Embest
Hermann.
$ cat /proc/cpuinfo
Hardware : BCM2708
Revision : 900093
Serial : 00000000fe1aea10
p
Manufacturer:
0x00 – Sony
0x01 – Egoman
0x02 – Embest
0x03 – Not used
0x04 – Embest
Hermann.
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/working_with_FPGAs
@HermannSW, I am not understanding how to read the list of manufacturers you listed. Here's what I show on my RPI3:
Hardware : BCM2709
Revision : a22082
Serial : 00000000aa13cfee
Hardware : BCM2709
Revision : a22082
- DougieLawson
DougieLawson wrote:https://github.com/AndrewFromMelbourne/ ... revision.c
Looks like your board was made by Embest.
How do i use the link you provided to decode the revision? I'm reading a bunch of things I don't understand, to which there is no explanation for a beginner to these things.
Revision : a22082
That's the key digit in finding the manufacturer. Match that up with the list HermannSW provided and you find that 0x02 (which is just hex notation for 2) is Embest. If that digit was a 0, then it would be a Sony, if it was a 1 then it would be Egoman.
Account Inactive
Thank you SonOfAMotherlessGoat. I appreciate that.SonOfAMotherlessGoat wrote:Revision : a22082
- HermannSW
"Revision : 900093" for my Pi Zero, decoding:
sony bmc2835 zero pcb
1 001
r 512MB
e
vision is bit encoded
- HermannSW
"Revision : a22082" seems to be unofficial since one entry is wrong:
BMC2837 is missing in Kolban's book, but in this link https://github.com/AndrewFromMelbourne/ ... revision.c pointed to above.
Nice:
A 2 2 08 2
Embest BMC2837 Not used pcb
(model)
1 010
r 1GB
e
Nice:
pi@raspberrypi01:~/raspberry_pi_revision-master $ ./test
memory: 512 MB
processor: Broadcom BCM2835
i2cDevice: /dev/i2c-1
model: Model Zero
manufacturer: Sony
pcb revision: 3
warranty void: no
revision: 900093
peripheral base: 0x20000000
checking peripheral base against bcm_host library
... peripheral base matches base from bcm_host
@HermannSW, here is a picture of what pops up when I use the 'cat /proc/cpuinfo' command.HermannSW wrote:"Revision : a22082" seems to be unofficial since one entry is wrong:BMC2837 is missing in Kolban's book, but in this link https://github.com/AndrewFromMelbourne/ ... revision.c pointed to above.Code: Select all
A 2 2 08 2 Embest BMC2837 Not used pcb (model) 1 010 r 1GB e vision is bit encoded
Nice:Code: Select all
pi@raspberrypi01:~/raspberry_pi_revision-master $ ./test memory: 512 MB processor: Broadcom BCM2835 i2cDevice: /dev/i2c-1 model: Model Zero manufacturer: Sony pcb revision: 3 warranty void: no revision: 900093 peripheral base: 0x20000000 checking peripheral base against bcm_host library ... peripheral base matches base from bcm_host pi@raspberrypi01:~/raspberry_pi_revision-master $
- Attachments
- Pi SSH pic.png (37.19 KiB) Viewed 2587 times
- HermannSW
Please download the .zip from here:
https://github.com/AndrewFromMelbourne/ ... i_revision
Then "make" and run "./test". You seem to have a Pi3, it seems that "0x08 Not used" seems to be changed to "0x08 Pi3" given your revision "a22082".
Hermann.
Hermann.
