Pi_Guy88
How Do I Find Out Who Manufactured My Pi??
Fri Aug 05, 2016 10:08 pm
Hello all,
I am needing to find out who manufactured my Pi. I do believe i have run by the process once before, but I don't remember how i did. I tried 'cat /proc/cpuinfo' , and it doesn't tell me who manufactured it. please help. Thanks to all whom help!!
Pi3B, Raspbian Jessie
Re: How Do I Find Out Who Manufactured My Pi??
Fri Aug 05, 2016 10:10 pm
cat /proc/cpuinfo does tell you, but it's encoded in the "Revision" field.
Pi_Guy88
Fri Aug 05, 2016 10:41 pm
@DougieLawson, Ahh, I see. So I did some research on this, and it turns out that the revision indicates that the manufacturer is unknown. It's very odd.The other revision codes on the list I found online show for Sony, and a couple other known manufacturers.
HermannSW
Fri Aug 05, 2016 10:43 pm
Kolban's book on Raspberry Pi has full details, you just need 2 digit of BCM revision, in case of my Zero its Sony:
$ cat /proc/cpuinfo
Hardware	: BCM2708
Revision	: 900093
Serial		: 00000000fe1aea10
p
900093
Manufacturer:
0x00 – Sony
0x01 – Egoman
0x02 – Embest
0x03 – Not used
0x04 – Embest
Hermann.
https://stamm-wilbrandt.de/working_with_FPGAs
Pi_Guy88
Fri Aug 05, 2016 11:12 pm
@HermannSW, I am not understanding how to read the list of manufacturers you listed. Here's what I show on my RPI3:
Hardware : BCM2709
Revision : a22082
Serial : 00000000aa13cfee
Sat Aug 06, 2016 12:20 am
https://github.com/AndrewFromMelbourne/ ... revision.c
Looks like your board was made by Embest.
Pi_Guy88
Sat Aug 06, 2016 1:08 am
DougieLawson wrote:https://github.com/AndrewFromMelbourne/ ... revision.c
How do i use the link you provided to decode the revision? I'm reading a bunch of things I don't understand, to which there is no explanation for a beginner to these things.
SonOfAMotherlessGoat
Sat Aug 06, 2016 1:40 am
Revision : a22082
That's the key digit in finding the manufacturer. Match that up with the list HermannSW provided and you find that 0x02 (which is just hex notation for 2) is Embest. If that digit was a 0, then it would be a Sony, if it was a 1 then it would be Egoman.
Account Inactive
Pi_Guy88
Sat Aug 06, 2016 2:15 am
SonOfAMotherlessGoat wrote:Revision : a22082
Thank you SonOfAMotherlessGoat. I appreciate that.
HermannSW
Sat Aug 06, 2016 9:43 am
"Revision : 900093" for my Pi Zero, decoding:
9     0     0        09    3
      sony  bmc2835  zero  pcb
1 001
r 512MB
e
vision is bit encoded
HermannSW
Sat Aug 06, 2016 11:57 am
"Revision : a22082" seems to be unofficial since one entry is wrong:
A     2       2        08        2
      Embest  BMC2837  Not used  pcb
                       (model)
1 010
r 1GB
e
BMC2837 is missing in Kolban's book, but in this link https://github.com/AndrewFromMelbourne/ ... revision.c pointed to above.
Nice:
pi@raspberrypi01:~/raspberry_pi_revision-master $ ./test
memory: 512 MB
processor: Broadcom BCM2835
i2cDevice: /dev/i2c-1
model: Model Zero
manufacturer: Sony
pcb revision: 3
warranty void: no
revision: 900093
peripheral base: 0x20000000
checking peripheral base against bcm_host library
... peripheral base matches base from bcm_host
Pi_Guy88
Sat Aug 06, 2016 7:42 pm
HermannSW wrote:"Revision : a22082" seems to be unofficial since one entry is wrong:
A     2       2        08        2
                       (model)
1 010
r 1GB
e
Nice:
memory: 512 MB
model: Model Zero
manufacturer: Sony
pcb revision: 3
warranty void: no
revision: 900093
@HermannSW, here is a picture of what pops up when I use the 'cat /proc/cpuinfo' command.
Pi SSH pic.png (37.19 KiB) Viewed 2590 times
HermannSW
Sat Aug 06, 2016 8:10 pm
Please download the .zip from here:
https://github.com/AndrewFromMelbourne/ ... i_revision
Then "make" and run "./test". You seem to have a Pi3, it seems that "0x08 Not used" seems to be changed to "0x08 Pi3" given your revision "a22082".
Hermann.
