I am using a raspberry pi 3b and have the latest raspbian installed.
When I connect to my WiFi (using the GUI) nothing happens. The icon has a small x in it. When I run the command ifconfig under lo it says LOOPBACK RUNNING... I have never seen that before?
I changed my router slightly today. I had to reset the password... my other Rpi3b had no problem?
Help!
Can't connect to internet?
I'm a total novice, non-programer (...basically a hack.)
Re: Can't connect to internet?
does the wireless interface show up under `ifconfig`? (eg. wlan0)
yes...FinlayDaG33k wrote:does the wireless interface show up under `ifconfig`? (eg. wlan0)
Link encap:Ethernet HWaddr ...
do you need the entire message?
pi@raspberrypi:~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:a6:cb:5c
inet addr:192.168.1.13 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::c68f:644a:f822:dbf8/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:17381 errors:0 dropped:0 overruns:0 frame:0
TX packets:18400 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1799639 (1.7 MiB) TX bytes:19609370 (18.7 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:221 errors:0 dropped:0 overruns:0 frame:0
TX packets:221 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:18228 (17.8 KiB) TX bytes:18228 (17.8 KiB)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:f3:9e:09
inet6 addr: fe80::61ff:99b5:63fc:36c7/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:157 errors:0 dropped:157 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:58162 (56.7 KiB) TX bytes:0 (0.0 B)
figured it out...
Deleted /etc/wpa_supplicant/wpa_supplicant.conf entries... then reconnected...
I need an advice too. Internet connection disappear when I reboot router. And doesn't connect before rebooting Raspberry. There is an error: signal 15 received. I try to add "wireless power off" in the interface. But there's no result. What can I do?
