CraigMuckleston
Switching on a 220v AC Mains bulb
Tue Aug 02, 2016 10:51 am
I want to power a light bulb (not led, I need a bulb that will produce heat) using my raspberry pi 3. Does someone know of a simple tutorial to wire up a bulb to the board?
scotty101
Re: Powering a light bulb
Tue Aug 02, 2016 10:57 am
What kind of bulb? What voltage, wattage etc?
You certainly shouldn't connect a traditional incandescent light bulb to the Pi without some form of simple driver like a transistor or relay.
W. H. Heydt
Tue Aug 02, 2016 6:32 pm
Check out "grain of wheat" bulbs that have been used extensively in model railroad work. You should be able to power one rated for 6V off the 5V lines as they don't require much current.
HawaiianPi
Tue Aug 02, 2016 7:39 pm
To drive a relatively high power device from a Pi you'll need to use a relay or a dedicated driver board. For a simple incandescent light bulb, a relay will probably be the simplest solution. You'll need a relay with a low voltage trigger that you would connect to a GPIO pin, and then by changing the state of that GPIO pin you could turn the relay on or off, which in turn would turn anything connected to the relay on or off.
If you are not familiar with relays, they are basically electrically controlled switches.
davidcoton
Tue Aug 02, 2016 9:40 pm
You need to give us the information scotty101 asked for. The answer is yes, but how to do it will vary a lot. If you want to control a mains light, there are significant safety issues.
CraigMuckleston
Wed Aug 03, 2016 7:01 am
Hi scotty101,
I am looking at a 220v 40w light bulb
davidcoton
Wed Aug 03, 2016 8:32 am
Are you familiar with working with mains voltage?
Are you familiar with the wiring standards for mains voltage in your country?
If not, it is important for your own safety, for fire protection of your property, and for the continued functionality of your Pi, that you consult a qualified electrician. Mains electricity can kill.
Mains must not get near your Pi. Use a relay board rated for switching mains, and designed for use with a Pi. Get it from a reputable supplier, not a random Chinese ebay seller.
For personal and fire safety, make sure the mains comes through an RCD protected socket or adapter. This can save your life -- and I am not exaggerating.
blaablaaguy
Wed Aug 03, 2016 6:34 pm
davidcoton wrote:Are you familiar with working with mains voltage?
Yep, dont mess with mains if you dont know what your doing. And dont try connecting it directly to a pi either, coz it will probably kill the pi.
This signature intentionally left blank.
pksato
Wed Aug 03, 2016 8:15 pm
After warnings about uses of mains ACs...
I recommend to use SSR (Solid State Relay), Its is safe and have circuitry to proper control AC.
SSR for 25A or more, like Fotek SSR-25 DA-H.
blaablaaguy
Wed Aug 03, 2016 9:10 pm
pksato wrote:Hi,
If he doesnt insulate his connections properly or forgets to turn off his electric or something like that he could kill or injure himself. (Right?)
klricks
Wed Aug 03, 2016 9:46 pm
pksato wrote:Hi,
No There is no difference as far as safety when using either an SSR or relay board with electro-mechanical relays. They both have similar screw terminals.
Wed Aug 03, 2016 9:59 pm
Good grief. Electricity is dangerous. https://en.wikipedia.org/wiki/Electric_shock
That does not mean you should not mess with it. Just take sensible precautions. Do your homework. Back in the day us young kids were building tube circuits with 500v DC supplies.
I would wager that the risk of death or serious injury among nerds toying with electricity is less than than of jocks playing football.
Also, remember, once you have built the thing and it works. Even if it is a low, harmless, voltage gadget. It can still fail, short circuit, burn the house down, kill your entire family. Months after you have forgotten about it.
texy
Re: Switching on a 220v AC Mains bulb
Thu Aug 04, 2016 6:41 am
[Title changed to a more appropriate one]
mfa298
Thu Aug 04, 2016 9:34 am
Heater wrote:Good grief. Electricity is dangerous. https://en.wikipedia.org/wiki/Electric_shock
There are some differences between now and then though. Back when some of us started doing electronics we would be using books to guide us and all the books I've seen had the standard disclaimers about working with mains electricity and usually guidance on how to work safely on mains equipment if you had to (particularly if it was live).
The other difference is we're now a more litigious society. If someone does get a shock, burn down their house etc. they'll potentially be looking for someone else to blame.
I tend to take the view that if people are asking questions on how to connect something like this up they're probably not ready to work with mains voltages safely, based off the other comments about safety I think that's a view shared by most others.
That's not to say the OP shouldn't have a goal to set something like this up, however the best path would likely to be starting off with a lower voltage bulb where the chances of anything going very wrong are much reduced. That way he can learn in relative safety and hopefully learn to respect electricity before working with anything harmful.
Thu Aug 04, 2016 9:50 am
How about this...
Go to your local hardware store and buy a 20 dollar wireless remote control power socket. Normally you get three in a pack and a remote control. Something like this: http://www.ebay.com/itm/3-Pack-Wireless ... SwwbdWIF8K
Open up the remote and hack hack the switches with a connection to the Pi GPIO.
Bingo. Nice and safe control of your light(s). No need to mess with mains wiring. Probably cheaper than buying relays and associated hardware.
B.Goode
Thu Aug 04, 2016 10:10 am
Or for a safe solution with no 'hacking' involved: https://energenie4u.co.uk/catalogue/product/ENER002-2PI
They just work straight out of the box. Where's the fun in that... ?
ejolson
Thu Aug 04, 2016 5:11 pm
mfa298 wrote:however the best path would likely to be starting off with a lower voltage bulb where the chances of anything going very wrong are much reduced.
You might be right, someone who asks about turning on and of a light bulb on this forum might be clueless and accident prone. On the other hand, you also see experienced engineers asking questions on this website who already know many ways but are interested in best practices. In this case the trade off is between a SSR and an electro-mechanical one.
Working with lower voltages allows for experimentation where the worst thing that can happen is ruining the Pi. However, once the resulting circuit works, it would be foolish to imagine that only the bulb and voltage needs to be changed to complete the project. Building something using mains current or any equipment that is dangerous or expensive requires knowledge and following best practices--an experimental style encouraged by a few clues given in a forum post isn't sufficient.
Maybe someone can recommend a good book on home automation that would help the original poster.
stderr
Thu Aug 04, 2016 5:26 pm
Absolutely, move to North America before starting any mains work.
CraigMuckleston
Fri Aug 05, 2016 7:25 am
Would it be better if I used a 12v bulb with an SSR?
RaTTuS
Contact: Twitter YouTube
Fri Aug 05, 2016 7:34 am
yes, and no,
exactly what is it you want to do ,
it is easy to flash a LED , harder to switch a 5W LED on and off , and harder to do mains voltage
Covfefe
CraigMuckleston
Fri Aug 05, 2016 7:54 am
I want to power a light bulb (not led, I need a bulb that will produce some heat)
RaTTuS
Fri Aug 05, 2016 8:22 am
OK why - there are better ways of obtaining heat ...
Covfefe
Fri Aug 05, 2016 8:32 am
How much heat?
A 12v halogen car headlamp is good for 100 watts or so.
B.Goode
Fri Aug 05, 2016 9:25 am
CraigMuckleston wrote:I want to power a light bulb (not led, I need a bulb that will produce some heat)
If you use the proprietary solution already suggested you can safely switch any load up to 3kW at mains voltage, which could include a dedicated heater.
CraigMuckleston
Fri Aug 05, 2016 12:34 pm
Thanks everyone, I think the 12v halogen lamp will do what I need.
