houkun1230
Raspberry pi 3 SD card can't be formatted
Tue Aug 02, 2016 1:19 am
Hi guys,
I just bought my RPi 3, and use 16G kingston micro SD card, unzip NOOBS in the sd card.
The problem that I meet is this error:
"error downloading or extracting tarball tar:write error Read-only system" which causes the OS can't be installed.
after that, I reboot RPi it keep showing "Waiting for SD card (settings partition)"
I've tried to use:
https://www.sdcard.org/downloads/formatter_4/
to format the sd card, and
http://brucesbraindump.blogspot.ca/2013 ... -from.html
to fix the readonly property of sd card, but I can't format the sd card.
It's very weird that my sd card becomes "RECOVERY" and the size is only 1.08G.
I'm very familiar with the sd card and noobs, is there any ideas?
Thank you
Re: Raspberry pi 3 SD card can't be formatted
Tue Aug 02, 2016 8:26 am
houkun1230 wrote:Hi guys,
I've tried to use:
Thank you
If you are using Windows to read the SD Card it will only show the first FAT Partition, yes MS does not understand EXT File System.
When using SD Card Formatter did you do so with "size adjustment ON" ?
I have found that formatting a supposedly 'bad' card in a Digital Camera has good results ;)
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
B.Goode
Tue Aug 02, 2016 10:39 am
houkun1230 wrote: It's very weird that my sd card becomes "RECOVERY" and the size is only 1.08G.
It is not at all "weird." This is the standard, documented, behaviour of the NOOBS Installer when it is booted for the first time.
It is unrelated to the problem you are experiencing with apparent corruption of your SD card.
houkun1230
Tue Aug 02, 2016 1:20 pm
I've tried to use:
Thank you
Yes, I turn the size adjustment "ON", when I click "format" it pops out a message: "sd card is write protected, please release the switch" which I don't have any switch at all. I also tried using MAC and Ubuntu to format it, it won't work. Any idea about that? thank you
houkun1230
Tue Aug 02, 2016 1:21 pm
Do you know how to fix that problem?
B.Goode
Tue Aug 02, 2016 1:38 pm
I agree with the suggestion that has already been made by @fruitoftheloom.
houkun1230
Wed Aug 03, 2016 4:45 pm
B.Goode wrote:I agree with the suggestion that has already been made by @fruitoftheloom.
But do you know why this card can't be formatted anymore?
fruit-uk
Wed Aug 03, 2016 4:47 pm
It may have gone into ReadOnly mode - means it's dead, something or action has corrupted/broken the card
B.Goode
Thu Aug 04, 2016 6:31 pm
What 'known issue' are you referring to in particular?
Early (beta) experiences with this alternative method of booting are unrelated to your difficulties involving a mis-behaving microSD card.
Thu Aug 04, 2016 6:48 pm
It has likely gone past it's read / write life and now unreliable :shock:
adieu
