HermannSW
Raspberry Pi Zero "cycle counter register" always returns 0?
Wed Jul 27, 2016 2:38 pm
Yesterday I successfully installed kernel header files needed to build kernel modules on Raspbian:
viewtopic.php?p=1015439#p1015439
Next I went to "the" page wrt. Raspberry CPU "cycle counter register":
http://blog.regehr.org/archives/794
The precompiled module did not work because I have a different kernel (4.4.11+), but compiling the kernel module worked without any issues.
I tried to use this small sample program to read the cycle couter register:
#include <stdio.h>
#include <unistd.h>
static inline unsigned ccnt_read (void)
  unsigned cc;
  __asm__ volatile ("mrc p15, 0, %0, c15, c12, 1":"=r" (cc));
  return cc;
int main()
  unsigned cc0,cc1;
  cc0 = ccnt_read();
  sleep(1);
  cc1 = ccnt_read();
  printf("%u %u\n",cc0,cc1);
  return 0;
All is fine, illegal instruction without installing the kernel mdoule, and normal run after installing:
[email protected]:~/raspbian-ccr $ ./tst
Illegal instruction
[email protected]:~/raspbian-ccr $ sudo insmod enable-ccr.ko
[email protected]:~/raspbian-ccr $ dmesg | tail -1
[ 2339.369603] User-level access to CCR has been turned on.
0 0
Although there is a 1 second sleep between both reads of cycle count register, both report 0 :-(
Just to be on the safe side I converted the litte test program to a kernel module:
#include <linux/module.h>
#include <linux/kernel.h>
//#include <linux/time.h>
#include <asm/delay.h>
 * works for ARM1176JZ-F
  unsigned cc;
  return cc;
int init_module(void)
  unsigned cc0,cc1;
  cc0 = ccnt_read();
  udelay(10);
  cc1 = ccnt_read();
  printk("%u %u\n",cc0,cc1);
  return 0;
void cleanup_module(void)
MODULE_LICENSE("GPL");
Unfortunately this code returns 0 two times as well:
[email protected]:~/raspbian-ccr $ sudo reboot 0
Connection to raspberrypi02.local closed by remote host.
Connection to raspberrypi02.local closed.
[email protected]:~$ ssh -X [email protected]
Warning: Permanently added the ECDSA host key for IP address '10.42.0.43' to the list of known hosts.
[email protected]'s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Jul 27 14:32:38 2016
[email protected]:~ $ sudo insmod raspbian-ccr/tst-1.ko
[email protected]:~ $ dmesg | tail -2
[   42.907963] random: nonblocking pool is initialized
[  201.024787] 0 0
I verified that the assembler statement for reading cycle counter is correct in manual:
http://infocenter.arm.com/help/topic/co ... f#page=270
Some questions:
  • Does cycle counter register work for Raspberry Pi Zero?
  • Is something needed to start cycle counter register?
  • Is reading cycle counter register the equivalent to Intel rdtsc and Arduino Due SysTick->Val?
Hermann.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
HermannSW
Re: Raspberry Pi Zero "cycle counter register" always return
Thu Jul 28, 2016 8:13 pm
After a lot of googling I found this relevant posting:
http://stackoverflow.com/questions/3247 ... ve#tab-top
It says that counters need to be enabled first. The code does help although it is for Cortex-A8. At the bottom you find a kernel module containing that code, with the replacement asm statements for Pi Zero's arm11, and with links to A8 as well as arm11 specs for each asm statement, Perhaps that is a good place to start investigation if you want help to get CPU clock cycle counter timing work for Pi Zero.
I reduced the problem to this really short kernel module:
/* Kernel Programming */
#define MODULE
#define LINUX
#define __KERNEL__
#include <linux/module.h>  /* Needed by all modules */
#include <linux/kernel.h>  /* Needed for KERN_ALERT */
#include <linux/delay.h>
  unsigned int t;
  printk(KERN_ALERT "Hello rd-1.\n");
  __asm__ volatile ("mrc p15, 0, %0, c15, c12, 0":"=r" (t));
  // Read Performance Monitor Control Register
  printk ("t=%x\n", t);
  t=1;
  __asm__ volatile ("mcr p15, 0, %0, c15, c12, 0":"=r" (t));
  // Write Performance Monitor Control Register
  udelay(10);
  return 0;
  printk(KERN_ALERT "Goodbye rd-1.\n");
It reads Performance Monitor Control Register (0), then writes it with 1 to enable all three counters and then reads it again. Although I inserted a delay of 10us (you can see that this delay happens on dmesg timestamps) the 2nd read returns 0 as well although I think 1 should be returned, shouldn't it?
[email protected]:~/arm11-1 $ sudo insmod rd-1.ko
[email protected]:~/arm11-1 $ sudo rmmod rd-1.ko
[email protected]:~/arm11-1 $ dmesg | tail -4
[ 1074.924256] Hello rd-1.
[ 1074.926731] t=0
[ 1074.926755] t=0
[ 1079.411175] Goodbye rd-1.
[email protected]:~/arm11-1 $ uname -r
4.4.15+
Any explanation, help or pointer to working Pi Zero code reading clock cycles is appreciated.
Hermann.
//  http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor?answertab=active#tab-top
#define MODULE
#define LINUX
#define __KERNEL__
static inline unsigned int get_cyclecount (void)
  unsigned int value;
  // Read CCNT Register
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbjjhaj.html
//asm volatile ("MRC p15, 0, %0, c9, c13, 0\t\n": "=r"(value));
  __asm__ volatile ("mrc p15, 0, %0, c15, c12, 1":"=r" (value));
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0360f/BIHCGFCF.html
  return value;
static inline void init_perfcounters (int32_t do_reset, int32_t enable_divider)
  // in general enable all counters (including cycle counter)
  int32_t value = 1;
  // peform reset:
  if (do_reset)
    value |= 2;     // reset all counters to zero.
    value |= 4;     // reset cycle counter to zero.
  if (enable_divider)
    value |= 8;     // enable "by 64" divider for CCNT.
//  value |= 16;  // export events to external ... (a8)
// [6:4] interrupts, 0 disable (arm11)
// [10:8] clear overflows
  value |= 0x380;
  // program the performance-counter control-register:
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbdeggf.html
// asm volatile ("MCR p15, 0, %0, c9, c12, 0\t\n" :: "r"(value));
  // enable all counters:
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbedifc.html
//  asm volatile ("MCR p15, 0, %0, c9, c12, 1\t\n" :: "r"(0x8000000f));
  // clear overflows:
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbidaah.html
//  asm volatile ("MCR p15, 0, %0, c9, c12, 3\t\n" :: "r"(0x8000000f));
  __asm__ volatile ("mcr p15, 0, %0, c15, c12, 0":"=r" (value));
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0360f/BIHCJBAA.html
  unsigned int overhead, t;
  printk(KERN_ALERT "Hello arm11-1.\n");
#if 0
  /* enable user-mode access to the performance counter*/
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbcjifb.html
//asm ("MCR p15, 0, %0, C9, C14, 0\n\t" :: "r"(1));
  __asm__ volatile ("mcr p15,  0, %0, c15,  c9, 0\n" : : "r" (1));
#endif
  /* disable counter overflow interrupts (just in case)*/
// http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0344k/Bgbhgacf.html
//  asm ("MCR p15, 0, %0, C9, C14, 2\n\t" :: "r"(0x8000000f));
// 0x8 => CCNT, f => other counters
// done for arm11 in init_perfcounters()
  // init counters:
  init_perfcounters (0, 0);
  // measure the counting overhead:
  overhead = get_cyclecount();
  overhead = get_cyclecount() - overhead;
printk("a\n");
  t = get_cyclecount();
  udelay(200);
  t = get_cyclecount() - t;
printk("o\n");
  printk ("ov=%u\n", overhead);
  printk ("dt=%u\n", t);
  return 0;
  printk(KERN_ALERT "Goodbye arm11-1.\n");
joan
Thu Jul 28, 2016 9:30 pm
It may be the sort of question the bare metal guys could answer. It seems pretty low level.
HermannSW
Fri Jul 29, 2016 5:53 pm
Searching this forum (bare metal) did not give a solution.
But googling for "arm11" and "cycle counter" did find this posting with code "Counting cycles on the Nokia N810":
http://bench.cr.yp.to/cpucycles/n810.html
Luckily Nokia N810 is arm11 based as the Raspberry Pi Zero, and the code worked without changes. Find infomation on how to build kernel modules on Pi Zero in initial posting:
[email protected]:~/cpucycles4ns-1 $ ll
total 8
-rw-r--r-- 1 pi pi 2711 Jul 29 17:12 cpucycles4ns.c
-rw-r--r-- 1 pi pi  162 Jul 29 17:12 Makefile
[email protected]:~/cpucycles4ns-1 $ cat Makefile
obj-m += cpucycles4ns.o
all:
	make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
	make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
[email protected]:~/cpucycles4ns-1 $ make
make -C /lib/modules/4.4.15+/build M=/home/pi/cpucycles4ns-1 modules
make[1]: Entering directory '/home/pi/linux-19cf22758bad1e120ee13a5170f59df560dfcdea'
  CC [M]  /home/pi/cpucycles4ns-1/cpucycles4ns.o
/home/pi/cpucycles4ns-1/cpucycles4ns.c: In function ‘device_read’:
/home/pi/cpucycles4ns-1/cpucycles4ns.c:31:20: warning: ignoring return value of ‘copy_to_user’, declared with attribute warn_unused_result [-Wunused-result]
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /home/pi/cpucycles4ns-1/cpucycles4ns.mod.o
  LD [M]  /home/pi/cpucycles4ns-1/cpucycles4ns.ko
make[1]: Leaving directory '/home/pi/linux-19cf22758bad1e120ee13a5170f59df560dfcdea'
Installing the kernel module (3 11) and removing the kernel module (155741306 155741306) report clock cycles in dmesg:
[email protected]:~/cpucycles4ns-1 $ sudo insmod cpucycles4ns.ko
[email protected]:~/cpucycles4ns-1 $ sudo rmmod cpucycles4ns.ko
[email protected]:~/cpucycles4ns-1 $ dmesg | egrep "^\[ (239|240)"
[ 2396.886833] cpucycles4ns starting
[ 2396.886860] cpucycles4ns creating device
[ 2396.886885] cpucycles4ns suggests mknod /dev/cpucycles4ns c 243 0
[ 2396.886894] cpucycles4ns enabling cycle counter
[ 2396.886902] cpucycles4ns 3 11
[ 2400.285792] cpucycles4ns removing device
[ 2400.285825] cpucycles4ns disabling cycle counter
[ 2400.285837] cpucycles4ns 155741306 155741306
[ 2400.285845] cpucycles4ns stopping
What the previous posting code named "overhead" (difference of two reads of cycle counter) is 11-3=8. Unlike the N810 the Pi Zero clock cycle precision is 1ns!!! The two clock cycle reads on module removal are the same value because all counters have been disabled by the preceding asm statement.
I am so happy to have working cycle counter start/read code. Now I need to understand what this code does differently to previous posting code. Also I don't need device "/dev/cpucycles4ns".
Hermann.
P.S:
See related 'Raspberry Pi Zero 1ns "cycle counter register"' thread with code samples:
viewtopic.php?f=63&t=155830
