RPiRoss
Physical Terminal
Tue Jul 26, 2016 7:43 pm
Good evening all,
Ever since I saw this photo... Image, I have been enamoured with the DEC VT220.
Given that these are now extremely hard to come by, in even half good condition, I would like to recreate one... Somehow...
My thoughts are to use a PiZero for the internals, some kind of 3D printing job for the casing, and the Raspberry Pi Touchscreen for the display.
Unfortunately, I don't have the faintest idea of where to start with either GPIO or 3D printing, this is simply just how I imagined it could be achieved.
I would be interested to hear from anyone who even has a remote inclination to help me try and achieve this outlandish goal.
Ross
kusti8
Re: Physical Terminal
Tue Jul 26, 2016 8:14 pm
There may be 3D models online. Then you can use that with certain websites to have them print it to you or you could look online for a broken one and gut it. The official screen is easy to connect.
davidcoton
Tue Jul 26, 2016 9:18 pm
Memories! VT220 were great terminals to use. I forget the actual screen size, but it was considerably larger than the 7" touchscreen (and quite possibly a different aspect ratio).
Signature retired
RPiRoss
Tue Jul 26, 2016 9:37 pm
davidcoton wrote:Memories! VT220 were great terminals to use. I forget the actual screen size, but it was considerably larger than the 7" touchscreen (and quite possibly a different aspect ratio).
I would be happy with a perhaps smaller modern equivalent ;)
Pithagoros
Tue Jul 26, 2016 9:44 pm
They certainly were bigger than 7", more like 13" and with a 4:3 aspect ratio. They were RS232 too, 25 or 9 pin d connectors.
My first job in the business was development of terminals to emulate DEC terminals. I do miss those simple days. When PCs became ubiquitous on desktops we developed software to emulate the terminals on the PC instead.
There is a good choice of terminal emulators in Linux that will cover your DEC requirements.
RPiRoss
Tue Jul 26, 2016 10:50 pm
Well you wouldn't be wrong at suggesting that there are plenty of terminal emulators out there, however I'm looking for a PHYSICAL terminal. No emulation.
ejolson
Tue Jul 26, 2016 11:24 pm
RPiRoss wrote:Well you wouldn't be wrong at suggesting that there are plenty of terminal emulators out there, however I'm looking for a PHYSICAL terminal. No emulation.
I believe the Pi has a serial port that can be converted to use RS232 signal levels easily enough. Once you've turned the Pi into a vt220, what are you going to do with it? While the obvious thing is to connect it to a DEC minicomputer, unless you work in a museum, those are even more difficult to find than working terminals.
Wed Jul 27, 2016 5:42 am
I have a Wyse60 terminal that used to be the console terminal on a Unix system in around 1997. It still works and I've used it with a Pi :-)
Pithagoros
Wed Jul 27, 2016 6:38 am
Yes, I understand that from your first comment. But if you are going to use a Pi Zero then you will need a software emulation to make it work like a VT220.
Unless you just want a Linux computer that looks like a DEC terminal.
Do remember that the big chunky keyboards with long travel keys are part of the experience.
frednet
Sat Mar 04, 2017 9:48 pm
I've been hoping to find some info on building a VT220 clone with a Pi Zero and cheap TFT screen and I'm surprised no-one has built one!
I assume you could strip a kernel to the absolute minimum if you know what you're doing, maybe Arch linux would be a good starting place, and as xorg wouldn't be required the footprint would be extremely small.
It appears that someone has done a similar thing on an Arduino, I assume using screen is the best bet on linux, would anyone else be interested with this?
Sat Mar 04, 2017 10:02 pm
Raspbian would be fine.
Write a VT100/220 terminal emulator using Qt 5. If you can't find such a thing already written.
Run the VT100/220 emulator straight into the frame buffer, no X Windows required.
Sounds like a sweet project.
k-pi
Sun Mar 05, 2017 11:47 am
Would it be the same to you if you just used Raspbian-lite, & connected to a small monitor like the Eyoyo 8"?
I like working at the command line at times, the built in VT's of Linux are good, you normally have 6 set up, & can swap between them using Ctrl+F1~6.
There are a couple of multiplexers if you just want to work from one VT, screen being one of them.
RPiRoss
Mon Apr 17, 2017 6:22 pm
Heater wrote:Raspbian would be fine.
Writing a terminal emulator is a bit out of my reach I'm afraid! But yes, it sounds cool right?!
k-pi wrote:Would it be the same to you if you just used Raspbian-lite, & connected to a small monitor like the Eyoyo 8"?
Unfortunately I'm looking for the look of the VT220. I think it looks awesome. But having a modern equivalent would be dreamy. I've made enquiries and refurbished models are £300+.
W. H. Heydt
Mon Apr 17, 2017 6:45 pm
PuTTY does VT220 emulation as I recall, so no need to write the software for that. It will handle serial communications, too. You could even set the color scheme to match the amber display.
Mon Apr 17, 2017 7:38 pm
Well there is the thing.
If you can run a Pi with no X Windows and configure the display to 80 columns by whatever rows you have a VT100 terminal display right there.
derpygeek
Tue Jul 04, 2017 7:34 am
well I could not find a physical terminal emulator for vt220 so I installed raspbian lite (raspbian without gui) instead :idea:
meenet
Fri Aug 04, 2017 9:27 pm
Can I use vt220 as a monitor
and run off raspberry pi where keyboard is connected to raspberry pi?
so i can use other keyboard via usb port.
