radnor302
Re: STICKY: USB boot now working on Pi3
Tue Feb 26, 2019 11:16 pm
davidcoton wrote:
Tue Feb 26, 2019 11:15 pm
radnor302 wrote:
Tue Feb 26, 2019 10:59 pm
Now it sends me a "B" in morse code (3 short flashes followed by a long from the green led next to the power led)
Isn't that "V", as in Beethoven's 5th symphony? IIRC "B" is dah-di-di-dit. :ugeek:
Yes, Sir! Shows how active I've been.... TNX OM
HawaiianPi
Wed Feb 27, 2019 12:09 am
Thank you the reply.
Still no joy..... Did every step.
Once I did the FAT32 with bootcode.bin I had the rainbow screen.
Then I added the file timeout (empty file) to the FAT32 partition.
As I recall, 4 flashes means the kernel is not loading.
What kind of USB drive are you using?
What are you using for a Pi power supply?
radnor302
Wed Feb 27, 2019 12:11 am
PNY 32G
PS that came with Pi
I deleted timeout and retried. - black screen
reforated FAT32 and copied bootcode.bin, usb - black screen
So, I dont know if it wrote anything to usb.
Putting it down for the evening.
Thanks again
HawaiianPi
Wed Feb 27, 2019 12:47 am
That is not helpful. Exactly what power supply is it?
  • Brand?
  • Model?
  • Rated power specs?
  • Does it have a built-in power cable or require a separate micro USB cable?
  • Is there a power switch on the cable?
There are a lot of cheap phone chargers being marketed as Raspberry Pi Power Supplies (phone chargers are not a power supplies).
Model of the PNY 32GB might be helpful as well. PNY makes a ton of different USB flash drives, and some of them are ludicrously slow (like the Attaché series).
radnor302
Wed Feb 27, 2019 1:57 am
PS vilros adapter 2.5a. No power switch or detachable cable.
Pny is turbo 3.0. Might be attache.
Also tried pny 128g microsd card elite-x in USB adapter
kingbily
Mon Mar 04, 2019 5:23 pm
Boot your Raspberry Pi from the USB mass storage device.
After five to ten seconds, the Raspberry Pi should begin booting and show the rainbow splash screen on an attached display.
Note that if the USB boot bit is set, you do not need to insert an SD card into the Raspberry Pi for USB boot to work.
Bluestacks Kodi Lucky Patcher
HawaiianPi
Sun Mar 10, 2019 2:00 am
It would be nice if it was really that simple, but for a lot of people it's not. The Raspberry Pi boot-loader is not compatible with all USB mass storage devices, resulting in problems for some people. Symptoms are either not booting at all, or cold boot works but reboot does not. And people who want to boot from a hard drive can have additional problems due to their power consumption and long spin-up times.
There used to be a USB 3.0 to SATA III adapter cable from a company called ELUTENG that was the Holy Grail of USB booting for the Pi. I tested it on more than a dozen SSD and HDD models from 6 different manufacturers and it worked on every drive I tried (powered only by the Pi's USB port). But alas, that adapter has been replaced by a new model that does not work as well. However, there appears to be an identical product available from TNP on Amazon USA, but not Amazon UK. I tested the TNP with SSD models from Silicon Power and Crucial, and HDD models from Toshiba and Western Digital, and it worked with all of them.
Oh, and the USB boot OTP bit is already set from the factory on the newer 3B+ and 3A+ models.
radnor302
Thu Mar 14, 2019 1:14 pm
Yeah, I'm 1 that cannot get it to boot from usb for anything...
I just recently added an external case and put in it a SSD. No joy :(
So, I'm giving up on USB boot for my Pi.
regroers
Wed Mar 20, 2019 5:44 am
Does it work on pi 2?
It is more fun to drive a slow car fast than to drive a fast car slow.
HawaiianPi
Wed Mar 20, 2019 10:58 am
The later version Pi2B v1.2 has the same SoC as the Pi 3B, so I believe it supports no-SD card USB boot. The earlier version 1.1 would need a FAT32 SD card with the bootcode.bin file on it (you can USB boot any consumer Pi model that way, even the Pi Zero).
Yeahthisisausername
Fri Mar 22, 2019 6:31 pm
$30-ish, 120 GB Kingston A400 SSD works flawlessly on my 3B+. Boots and reboots just fine. Now you know.
HawaiianPi
Fri Mar 22, 2019 6:41 pm
And what USB-SATA adapter are you using?
Because SSD boot problems are almost always the fault of the USB-SATA adapter (now you know).
WarLion
Sun Apr 07, 2019 9:17 pm
Hi guys i got 3 raspberry pi 3b+ a year ago i decide to change my sd-card to a usb drive on my old rpi 3 , everything works fine , but today i decide to make a copy of my pi to another one but with sd-card
after reading and writing with win32Diskimage i place the sd-card on another pi , but i get error
Kernel panic-not syncing: VFS: unable to mount root fs on unknown- block(179,2)
is there a way to clone the usb drive back to sdcard?
i try changing the cmdline.txt but now the pi stuck on unnamed net_device
thanks guys
HawaiianPi
Mon Apr 08, 2019 5:30 pm
Use the SD Card Copier utility included with desktop versions of Raspbian (with New Partition UUIDs checked)..
sushant_ocv
Thu May 30, 2019 6:12 am
Hey mate,
Will booting from my external HDD minimize file system corruption issues which right now coming through SD Disk when power is gone?
Please provide your views.
HawaiianPi
Thu May 30, 2019 7:25 am
Hey mate,
No it will not.
Power loss without a proper software shutdown always has the risk of data loss or corruption with most commonly used operating systems (Raspbian, Windows, Mac OS, etc.). There are some threads about making the Raspbian root file system read-only, which should protect the OS, but that will not protect user data that's being written when power is lost. You could also try Tiny Core Linux, that runs entirely from RAM, which would also protect the OS from corruption, but user data is still at risk.
There is no way to completely protect a system from unscheduled power loss unless no data is ever written.
