I need help some help finding an adapter and searching is not helping.
What is the male to male adapter called that is found with this screen and where can I get it?
http://www.ebay.co.uk/itm/5-inch-Resist ... SwpIdW8Rit
Your help will be greatly appreciated as I need it for my car pc project as I am unable to find a hdmi connection small enough to fit in the case.
Male to Male adapter?
Back in the old days, we were smarter then the technology.
Nowadays technology makes us look like villages fools in front of the children!
Re: Male to Male adapter?
Some male/male or female/female adapters are called "gender changers" or "gender benders". I don't know if that's the case for the one you want, though, but you try searching using that terminology.
hello
below are some of the options which may be of interest to you
http://www.tinylcd.com/tiny149/category ... ategory=30
regards
tinylcd
regards
tinylcd
Using an internet search tool with the string "HDMI coupler male.to.male" returns lots of apparently relevant hits. Substituting 'extender' might be useful too.
I have ordered a 270 degree adapter but space is realy tight and I hope that fits otherwise I will need the U shaped adapter and I really don't want to order a cheep screen just to get it
Picked up a 270 degree connection, stripped off the plastic and its still to big.
You are probably going to have to make one out of the connector and some wire. Or go with a flat/thin HDMI cable. Most will be 1 foot. There is also the Right or Left angle connectors for Male to Female. http://www.ebay.com/itm/New-90Degree-le ... 2318685636
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
