I went to raspi-config and found out that it is not possible to overclock the Pi3 like it was with earlier models.
At least that's what it said-is there a way to overclock the Pi3?
Doug Byfield
Thanks muchly!RaTTuS wrote:by editing the config.txt file
Perfect, thanks!
Thanks very much, AikonCWD that's very useful.AikonCWD wrote:I recommend to read this article: http://aikoncwd.github.io/rpi-benchmark/ (made by me, lol).
You will find a small but powerfull benchmark script to measure how your overclock settings are boosting your RPi, also you can see the temperature on each test. At the end of the article you will find a perfect config.txt for RPi3 and RPi2, to max the overclock without damagin the hardware or warranty.
