homerguy
Which Minecraft Server for the Pi?
Thu Aug 23, 2012 2:32 pm
I know this is a semi-hot topic. My question is,
MC-Server or Mineserver.be ?
Which one runs better on the Pi?
homerguy
Re: Which Minecraft Server for the Pi?
Thu Aug 23, 2012 6:28 pm
I guess I can install both and check the resource consumption.
I will post it to a new thread when I get the chance.
homerguy
Fri Aug 24, 2012 4:34 am
okay so I did not run any resource tests on MC-Server because its glitched and crashes when you try to background it. But here is my review for both:
Mineserver.be - Runs great, works with the latest build, doesn't use a lot of resources on the Pi WHEN it is not generating chunks. Chunks does spike it but it is still 90% playable, haven't tested with more than 1 client connected, will do that later. Pretty straightforward setup, takes about 40 minutes to compile and build. Drawbacks are that not a lot of plugins are supported/written yet, so it is pretty vanilla. No hostile mobs only passive, but there seems to be a plugin for hostile ones, will look into to it later. Overall I like this server, going to try it with some friends later and maybe try a stress test using users from this forum.
MC-Server - The server only works with clients 1.2.4 and 1.2.5. Takes some time to generate chunks when server is booted up. Takes even longer to generate chunks when a client connects, just keeps going. At point I even hit a segfault and it crashed the server. Its pretty glitchy and laggy at times. I am pretty sure it has all of the features of a 1.2.5 server including mobs and all that, will explore more to find out. It has a vast set of plugins you can install, uses Lua plugins. Need further testing to check stability and other issues.
Maybe I will make a blog post or something later with more detail and stats.
MrT00Tall
Mon Sep 03, 2012 3:52 am
I think mineserver.be would be the best bet.
They are trying to create a bridge between bukkit plugin api and their own. But I really dont think that would be good. As bukkit is java based and it likes to hog up resources. I really hope people begin making plugins for it.
