homerguy
Mineserver.be on RPI
Thu Aug 23, 2012 5:17 am
I have setup the mineserver.be server,
I was wondering how do I make the server globally available and not just local. Same goes for SSH, how would I make it global, do I need to install a VPN package?
alexeames
Re: Mineserver.be on RPI
Thu Aug 23, 2012 5:35 am
You need to set up port forwarding on your router and you need to know your router's IP address. Then either point people to the IP address or get a domain name and point the domain name to the IP address.
Alex Eames RasPi.TV, RasP.iO
homerguy
Thu Aug 23, 2012 1:27 pm
Will I have to do TCP or UDP?
LetHopeItsSnowing
Thu Aug 23, 2012 1:30 pm
You could also use a dynamic IP service. I have setup no-ip on my Pi to provide access to a webserver and it works a dream, see http://stuffaboutcode.blogspot.co.uk/20 ... using.html
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
homerguy
Thu Aug 23, 2012 2:08 pm
LetHopeItsSnowing wrote:You could also use a dynamic IP service. I have setup no-ip on my Pi to provide access to a webserver and it works a dream, see http://stuffaboutcode.blogspot.co.uk/20 ... using.html
Beautiful, thank you very much
