Fght
a pc and pi with the same mouse and keyboard
Tue Jun 28, 2016 7:59 pm
i've both wireless and wired ones now
the wired are for the pc
the wireless for the pi (raspbian)
i don't want to switch them when switching between the computers...
how can it be done?
i've an hdmi switch but without the sound and of course without the mouse and keyboard.
HawaiianPi
Re: a pc and pi with the same mouse and keyboard
Tue Jun 28, 2016 8:22 pm
You need something called a KVM switch (keyboard, video, mouse switch). And if you are using the analog audio, you will want one that supports that as well.
EDIT: Here's one I found on Amazon.
http://www.amazon.com/dp/B00FSARCX0
Here's a cheaper one, but it only supports HDMI (digital) audio.
http://www.amazon.com/dp/B00ANSVQPW
W. H. Heydt
Tue Jun 28, 2016 8:36 pm
Or...you can do remote VNC access to the Pi.
Romonga
Tue Jun 28, 2016 8:42 pm
If you don't need video to switch a software solution does exist for keyboard an mouse. Synergy http://symless.com/synergy/
However, it seems you also need video.
You can run, but you will only die tired.
broe23
Tue Jun 28, 2016 10:30 pm
SSH is the best way. Use WinSCP with Putty on the PC. Just be aware that if you use any type of KVM switch that does not do a keep alive signal on the device not in use with the KVM, you will see a lot of no device found errors.
I have a monitor with both VGA and DVI that I had the PC on one and the Pi on the other with a DVI to HDMI adapter, no sound. For the mouse It was only for the PC, the Keyboard was through a A/B switch that worked out pretty decent with the Pi not needing a GUI as a headless unit.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
Fght
Wed Jun 29, 2016 12:10 pm
thank you for the variety of suggestions.
i will stick with the vnc i guess
