Wifi is not working on Raspberry Pi 3
Posted: Mon Jun 27, 2016 8:44 am
by ashutripathi
[email protected]:~ $ dmesg | grep brcm
[ 5.753113] brcmfmac: brcmf_chip_recognition: SB chip is not supported
[ 5.753137] brcmfmac: brcmf_sdio_probe_attach: brcmf_chip_attach failed!
[ 5.753150] brcmfmac: brcmf_sdio_probe: brcmf_sdio_probe_attach failed
[ 5.753924] brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
[ 5.754168] usbcore: registered new interface driver brcmfmac
i have problem with wifi, it says no wireless interfaces found and when i dmesg it gives me the above results. i am using Raspbian jessie and Raspberry Pi 3.
Re: Wifi is not working on Raspberry Pi 3
Posted: Mon Jun 27, 2016 8:50 am
by davidcoton
Is that a current version of Jessie, or an older one? (Don't assume that a card bought with Jessie is current.) IIRC you need the version released in late May 2016.
Posted: Mon Jun 27, 2016 8:53 am
by ashutripathi
I have Downloaded Jessie from Pi website at its latest version and also tried rpi update.
The first time i installed jessie - The wifi was working, but after a restart this problem started and the icon on the upper right hand corner says, NO WIRELESS INTERFACES FOUND.
Posted: Wed Jun 29, 2016 7:53 am
by ashutripathi
I humbly request you all to help me out as i have sold my old computer and have taken raspberry Pi. I have Great hopes from it, atleast it should give me sufficient basic functionalities.
Posted: Wed Jun 29, 2016 8:53 am
by HawaiianPi
What are you using as a power supply?
Posted: Thu Jun 30, 2016 8:49 am
by ashutripathi
I have purchased a 2.1 amp output charger from amazon branded as STUDIO-Y.
Please find the link below
http://www.amazon.in/dp/B00IJCDBZM
Please suggest me what could be the problem.
Posted: Mon Apr 03, 2017 3:59 am
by saurabhchakrabarti
Did you find any resolution to this?
Posted: Tue Apr 04, 2017 12:44 am
by soydepr
show your interfaces and wpa_suppolicant files
Posted: Tue Apr 04, 2017 6:10 pm
by DougieLawson
It won't work if your network uses WEP security. Change your network to use WPA or WPA2 (which is more secure anyway). Or add some strange extra parameters to your supplicant file.
