vk4tec
Static ip won't stick
Sun Jun 26, 2016 9:47 am
Hello
Edited /etc/networks/interfaces
Eth0 static address static
Went back to DHCP
Also how do I turn of wlan0 on a raspberry Pi 3 ?
Andrew Rich
email: [email protected]
http://www.tech-software.net/ ( hobby website )
http://59.167.159.165/ ( Raspberry Pi ADS-B server ) RTL SDR
pcmanbob
Re: Static ip won't stick
Sun Jun 26, 2016 10:04 am
Hi.
You have not stated which operating system you are using but guessing its raspbian and Jessie full or lite.
If this is correct you should not be editing "/etc/networks/interfaces" any more to set static IP address you should now be using "/etc/dhcpcd.conf"
you should return your interfaces file to how it was before you edited it and then make the changes in dhcpcd.conf
a google search for "static ip jessie" will generate plenty of results but just in case here's one such result
https://pi-hole.net/faq/how-do-i-set-a- ... cpcd-conf/
and a post from this very forum
viewtopic.php?f=91&t=152635
knute
Sun Jun 26, 2016 9:18 pm
I wrote a Java GUI program to set up a static IP. Find it here: http://knutejohnson.com/ipconfig. You can even use it to fix what you've done to your /etc/interfaces file.
