Reset Pi 3
Posted: Sat Jun 25, 2016 8:12 pm
by donnyl543
I just received my new pi 3 and installed Raspian. When I realized my mistake by not installing openelec I tried to install it over Raspian. Now my pi doesn't even boot up.
Anybody have a solution on how I can reset and reinstall?
Thanks,
Donny
Re: Reset Pi 3
Posted: Sat Jun 25, 2016 8:58 pm
by DougieLawson
If you have NOOBS on your SDCard then hold [SHIFT] while you boot and use the NOOBS recovery system to re-install.
If you have anything else, then use a Windows machine to re-write your SDCard.
Re: Reset Pi 3
Posted: Sat Jun 25, 2016 9:11 pm
by donnyl543
Thank you for the fast reply. I am very new to this. I had a friend set up my first Raspberry pi 2 and one pi3 and we never used a computer during the installation. Just plugged it in and connected HDMI cable to my TV.
When you mention to hit the shift key I am at a loss.
Donny
Re: Reset Pi 3
Posted: Sat Jun 25, 2016 9:13 pm
by mahjongg
read the boot problem sticky.
doughy means you should repeatedly press/release shift while the PI starts up, so as to re-evoke NOOBS.
Re: Reset Pi 3
Posted: Sat Jun 25, 2016 9:33 pm
by donnyl543
Once again...There is no shift key on the Raspberry Pi. I am not using it on a laptop pc or mac. I have it connected directly to my TV.
Donny
Re: Reset Pi 3
Posted: Sat Jun 25, 2016 9:52 pm
by SonOfAMotherlessGoat
Try doing it with a USB keyboard plugged into the Pi.
Re: Reset Pi 3
Posted: Sat Jun 25, 2016 10:13 pm
by fruitoftheloom
Re: Reset Pi 3
Posted: Sun Jun 26, 2016 12:41 am
by donnyl543
Great. Thanks guys it worked. Now all I have to figure out is how to install openelec.
Donny
Re: Reset Pi 3
Posted: Sun Jun 26, 2016 3:52 am
by W. H. Heydt
donnyl543 wrote:Great. Thanks guys it worked. Now all I have to figure out is how to install openelec.
Donny
If you're using NOOBS, you'll need (at least) an internet connection. Since I don't use it, I'm not sure what the current state of OepenElec is...whether or not there is a release that supports the Pi3B.
Re: Reset Pi 3
Posted: Sun Jun 26, 2016 4:26 am
by fruitoftheloom
W. H. Heydt wrote:donnyl543 wrote:Great. Thanks guys it worked. Now all I have to figure out is how to install openelec.
Donny
In NoobS LibreElec is offered in place of OpenElec, as has been discussed elsewhere some OpenElec developers forked OpenElec.
To OP, yes you need an Internet Connection as per the link to the readme above states...
Re: Reset Pi 3
Posted: Sun Jun 26, 2016 4:41 am
by klricks
Donny
The NOOBS installer now installs LibreELEC
https://libreelec.tv/ instead of OpenELEC.
As mentioned you will need to have an Internet connection on the RPi (wired or WIFI) in order to get any OS other than Raspbian.
If you want OpenELEC then you will need to download the OS image from their web site and install manually with Win32diskimager (Not NOOBS).
http://openelec.tv/
Re: Reset Pi 3
Posted: Sun Jun 26, 2016 4:51 am
by fruitoftheloom
klricks wrote:donnyl543 wrote:Great. Thanks guys it worked. Now all I have to figure out is how to install openelec.
Donny
http://openelec.tv/
..or use PINN for OpenElec:
viewtopic.php?f=63&t=142574
