nghia
Re: SPI on final PCB
Sun Nov 27, 2011 9:03 pm
Hello R-PI team,
Could you confirm that SPI is available on the expansion header on the final PCB?
If so, is a SPI driver plan for the first release?
Nghia.
liz
Sun Nov 27, 2011 9:05 pm
A driver is not planned for the first release (we hope the community might write one), but yes, SPI is available on the header.
trogper
Mon Nov 28, 2011 3:48 pm
what about just GPIO driver?
will it be available?
abishur
Mon Nov 28, 2011 4:26 pm
I believe the answer to that one is that the standard linux interface for GPIO should be sufficient. Otherwise see liz's post above except replace SPI with GPIO :P
Dear forum: Play nice ;-)
mahadevan
Mon Nov 28, 2011 4:52 pm
Till R-pi team gives SPI-drivers in future editions, one can use SPI over GPIO using bit-banging.
Some working SPI/I2C drivers in linux are vailable in OpenWRT/DD-WRT projects .
nghia
Tue Nov 29, 2011 9:17 pm
Hi Liz,
In order to enable one to develop a SPI driver, would you release the required information on the SPI block of the Broadcom SoC? If yes, when could you release such info?
tntexplosivesltd
Tue Nov 29, 2011 9:20 pm
From memory, it has been stated that we will be provided with full documentation
Warringer
Wed Nov 30, 2011 7:10 pm
In the meantime it should be possible to bit-bang the SPI with the GPIO.
vacoloco
Sat Dec 31, 2011 11:26 pm
Is this still the case? I mean, that initially SPI won't be supported in the kernel build?
For me, this is a key feature as I want to interface to an FPGA and some SPI DACs.
Michael
Sun Jan 01, 2012 1:22 pm
Yes, this is still the case.  There is no appropriate SPI driver in the upstream so it'll have to be written and the Raspberry Pi team are far too busy getting the board out of the door and all the other tasks such as getting an office set up, geting cases designed, getting documentation in place and getting legals sorted, to be writing SPI drivers any time soon.  Its simply too far down in their list of priorities.
Writing an SPI driver would seem, on the face of it, exactly the kind of task of which the community would be capable.  I'm sure that such a driver would emerge in the months after the boards start getting into the hands of the enthusiasts.
jwatte
Sun Jan 01, 2012 7:18 pm
Send me a board and the register description and I'll write you a driver right away
David Calvo
Tue Jan 03, 2012 2:00 pm
See
http://www.raspberrypi.org/for.....ing/page-2
I do not think drivers are a problem
