pUnK
Teamspeak 3 Server on Raspberry Pi
Sun Jun 05, 2016 11:03 pm
Below I post step-by-step instruction How to run Teamspeak 3 Server on Raspberry Pi with ExaGear Desktop https://eltechs.com/product/exagear-des ... nd-prices/. Please note that ExaGear isn't free. But I hope it will help someone.
  1. Install ExaGear Desktop, which allow to run x86 software on Raspberry (note that ExaGear isn't free and you have to obtain the license)
    tar -xvzpf exagear-desktop-rpi2.tar.gz
    sudo ./install-exagear.sh
  2. Run ExaGear
    exagear
    Now you entered in x86 world.
  3. Don't run Teamspeak 3 Server under root, create special user
    sudo adduser teamspeak
    sudo passwd teamspeak
  4. Create installation directory and make teamspeak user the owner of this directory:
    sudo mkdir /usr/local/teamspeak
    sudo chown teamspeak /usr/local/teamspeak
  5. Login as teamspeak user, download ts3 server and unpack archive:
    su teamspeak
    cd /usr/local/teamspeak
    wget http://dl.4players.de/ts/releases/3.0.11.4/teamspeak3-server_linux-x86-3.0.11.4.tar.gz
    tar -xzvf teamspeak3-server_linux-x86-3.0.11.4.tar.gz
    rm teamspeak3-server_linux-x86-3.0.11.4.tar.gz
  6. Start ts3 server
     /usr/local/teamspeak/teamspeak3-server_linux-x86/ts3server_minimal_runscript.sh
    Your Teamspeak 3 server is running. You should copy credentials which will be required for connecting with teamspeak 3 client.
  7. Press CTRL+C and then start the Server in the background
    /usr/local/teamspeak/teamspeak3-server_linux-x86/ts3server_startscript.sh start
ExaGear Desktop - run x86 apps on Raspberry Pi
pUnK from Eltechs
ghodan
Re: Teamspeak 3 Server on Raspberry Pi
Mon Jun 06, 2016 6:08 am
Cool. But how many users can a Pi3 handle?
pUnK
Mon Jun 06, 2016 12:55 pm
ghodan wrote:Cool. But how many users can a Pi3 handle?
32 users (limits for free ts3 server) is definitely works great. It Generate less than 50% CPU workload. So, approximating 70 users should work ok.
pUnK from Eltechs
lam000
Fri Nov 11, 2016 11:17 am
is it worth to run a teamspeak server with ~20 slots compared to renting one?
cause a teamspeak server with ~slots costs ~12€ a year.
So the question is how many kwh is a pi consuming in a year
when there is only a teamspeak server...
Regards
tweak42
Fri Nov 11, 2016 6:49 pm
lam000 wrote:is it worth to run a teamspeak server with ~20 slots compared to renting one?
Regards
I've both run my own and rented for gaming with friends. It depends on usage. To get the cheapest rent price you need to pay for a year, but if you only end up using it for 2-3 months before everyone gets bored and moves on to a new game, then running your own is cheaper.
In the last year Discord has been my preferred gaming voip program. The free dedicated server infrastructure works well and there is a client for nearly any platform even a experimental x86 linux client. My main concern is they don't have profit model in place yet, so they might suddenly start charging for certain features or dropping in ad banners.
