Ethernet connection problem
Posted: Wed Jun 01, 2016 1:41 pm
by kamal318
Hi Friends,
My router got spoilt due to power surge. And I have to enter the login username and password manually every time I log into broadband connection. In windows I am able to do this quite easily , whereas I am a novice to Linux and raspberry pi.
I have no idea how to log into my broadband connection through Ethernet cable. Please help me.
Re: Ethernet connection problem
Posted: Thu Jun 02, 2016 7:10 am
by broe23
The answer is that you do not have to enter anything. Also what is "spoilt"? It it got hit by a surge, you need to buy a new gateway.
Posted: Thu Jun 02, 2016 7:29 am
by SonOfAMotherlessGoat
Spoilt http://www.dictionary.com/browse/spoilt
As for the OP, when you are in Windows, how do you enter the credentials? Do you need to open a browser and then enter user/pass via webpage? What distribution do you have installed on the Pi (is it running just command line or do you have a graphical interface installed?)
Posted: Thu Jun 02, 2016 7:38 am
by kamal318
SonOfAMotherlessGoat wrote:Spoilt http://www.dictionary.com/browse/spoilt
Well, I am using Rasbian. In windows 8.1, I click the system tray icon of Network connections and it opens a side sliding window of connections. There under broadband connections, I enter the credentials.
Posted: Thu Jun 02, 2016 7:41 am
Do you know if your provider is using PPPoE? Did your provider give you a modem of any type, like for a DSL connection?
Posted: Thu Jun 02, 2016 7:47 am
by kamal318
SonOfAMotherlessGoat wrote:Do you know if your provider is using PPPoE? Did your provider give you a modem of any type, like for a DSL connection?
No, the provider did not give me any modem. But I am sure the connection has to dial to PPPoE or something similar.
