mydreamcar
RPI3 wifi connection issue (or country code setting)
Tue May 31, 2016 2:27 am
rpi3 After i set as follows, there is no connection to try to connect to the ap router in rpi3.
cat /etc/network/interface
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
cat /etc/wpa_supplicant/wpa_supplicant.conf
country=JP
update_config=1
wifi was to ensure that it works in the rpi3 as follows.
ifconfig -a
[email protected]:/usr/share/zoneinfo# ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:a1:f3:2d
          inet addr:192.168.0.16  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::5786:7f55:11eb:d4d/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:6707 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7985 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:438785 (428.5 KiB)  TX bytes:2322112 (2.2 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:200 errors:0 dropped:0 overruns:0 frame:0
          TX packets:200 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:16656 (16.2 KiB)  TX bytes:16656 (16.2 KiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:f4:a6:78
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:2374 errors:0 dropped:2361 overruns:0 frame:0
          TX packets:29 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:919246 (897.7 KiB)  TX bytes:3734 (3.6 KiB)
iwconfig wlan0
[email protected]:/usr/share/zoneinfo# iwconfig wlan0
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:on
iwlist wlan0 channel
[email protected]:~# iwlist wlan0 channel
wlan0     14 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
          Channel 14 : 2.484 GHz
iwlist wlan0 scan
wlan0     Scan completed :
          Cell 01 - Address: 00:08:9F:B0:39:11
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=70/70  Signal level=-22 dBm
                    Encryption key:on
                    ESSID:"idolamba"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
                              18 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 100ms ago
                    IE: Unknown: 000869646F6C616D6261
                    IE: Unknown: 010882848B961224486C
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 32048C98B060
                    IE: Unknown: 2D1AEE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: 3D1601050600000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Authentication Suites (1) : PSK
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: 7F0101
                    IE: Unknown: DD07000C4307000000
                    IE: Unknown: 07064B5220010D10
                    IE: Unknown: DD1E00904C33EE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: DD1A00904C3401050600000000000000000000000000000000000000
In the notebook computer, it is connected to the same ap router.
I tried to connect to the wpa_cli as follows but not connect.
<3>CTRL-EVENT-SCAN-STARTED
<3>CTRL-EVENT-SCAN-RESULTS
<3>WPS-AP-AVAILABLE
<3>CTRL-EVENT-SSID-REENABLED id=1 ssid="idolamba"
<3>Trying to associate with SSID 'idolamba'
<3>Associated with 00:08:9f:b0:39:11
<3>CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=KR
<3>CTRL-EVENT-DISCONNECTED bssid=00:08:9f:b0:39:11 reason=0 locally_generated=1
<3>CTRL-EVENT-SSID-TEMP-DISABLED id=1 ssid="idolamba" auth_failures=2 duration=20 reason=CONN_FAILED
<3>CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
<3>CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=JP
<3>WPS-AP-AVAILABLE
CTRL-EVENT-DISCONNECTED occurs for country code?
I guess with the country code the cause of the disconnect.
so I was rebooting rpi3 after changing the option of wpa_supplicant.conf to "country=KR"
ifconfig wlan0
          inet6 addr: fe80::cb31:fae6:25ff:328a/64 Scope:Link
          RX packets:2 errors:0 dropped:2 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:123 (123.0 B)  TX bytes:0 (0.0 B)
iwconfig wlan0
[email protected]:~# iwconfig wlan0
          Encryption key:off
          Power Management:on
wlan0     0 channels
iwlist wlan0 scan
[email protected]:~# iwlist wlan0 scan
wlan0     Interface doesn't support scanning : Invalid argument
i restarted wpa_supplicant process in debug mode, but don't start.
[email protected]:~# /sbin/wpa_supplicant  -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf -d
wpa_supplicant v2.3
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'nl80211,wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
country='KR'
ctrl_interface='DIR=/var/run/wpa_supplicant GROUP=netdev'
update_config=1
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
rfkill: initial event: idx=1 type=2 op=0 soft=0 hard=0
nl80211: Using driver-based roaming
nl80211: TDLS supported
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x551929a8
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=0801
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=040e
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x551929a8 match=0a11
netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
nl80211: driver param='(null)'
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=KR (DFS-JP)
nl80211: 2402-2482 @ 40 MHz 20 mBm
nl80211: 5170-5250 @ 80 MHz 20 mBm
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS)
nl80211: 5490-5710 @ 160 MHz 30 mBm (DFS)
nl80211: 5735-5835 @ 80 MHz 30 mBm
nl80211: Added 802.11b mode based on 802.11g information
nl80211: Do not indicate P2P_DEVICE support (p2p_device=1 driver param not specified)
wlan0: Own MAC address: b8:27:eb:f4:a6:78
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: State: DISCONNECTED -> INACTIVE
TDLS: TDLS operation supported by driver
TDLS: Driver uses internal link setup
wlan0: WPS: UUID based on MAC address: 97ce58c1-2234-569c-ac60-73a42ef687e2
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
ctrl_interface_group=108 (from group name 'netdev')
P2P: Failed to select random social channel as listen channel
wlan0: Failed to init P2P
Failed to add interface wlan0
wlan0: Request to deauthenticate - bssid=00:00:00:00:00:00 pending_bssid=00:00:00:00:00:00 reason=3 state=INACTIVE
TDLS: Tear down peers
wlan0: State: INACTIVE -> DISCONNECTED
nl80211: Set wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
wlan0: Cancelling delayed sched scan
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
Remove interface wlan0 from radio phy0
Remove radio phy0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Unsubscribe mgmt frames handle 0xdd91a121 (mode change)
I was rebooting after changing the option of wpa_supplicant.conf to "country=JP"
[email protected]:~# iw reg get
country JP: DFS-JP
        (2402 - 2482 @ 40), (N/A, 20), (N/A)
        (2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM
        (4910 - 4990 @ 40), (N/A, 23), (N/A)
        (5030 - 5090 @ 40), (N/A, 23), (N/A)
        (5170 - 5250 @ 80), (N/A, 20), (N/A)
        (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS
        (5490 - 5710 @ 160), (N/A, 23), (0 ms), DFS
starting wpa_supplicant process in debug mod. and it works fine
wpa_supplicant v2.3
country='JP'
update_config=1
nl80211: Subscribe to mgmt frames with non-AP handle 0x556329a8
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=0801
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=040e
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x556329a8 match=0a11
nl80211: Regulatory information - country=JP (DFS-JP)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM)
nl80211: 4910-4990 @ 40 MHz 23 mBm
nl80211: 5030-5090 @ 40 MHz 23 mBm
nl80211: 5490-5710 @ 160 MHz 23 mBm (DFS)
P2P: Add operating class 81
P2P: Channels - hexdump(len=13): 01 02 03 04 05 06 07 08 09 0a 0b 0c 0d
P2P: Own listen channel: 81:11
P2P: Random operating channel: 81:6
P2P: initialized
P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11,12,13
P2P: cli_channels:
wlan0: Added interface wlan0
random: Got 18/20 bytes from /dev/random
RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP])
random: Got 2/2 bytes from /dev/random
EAPOL: disable timer tick
wifi connection fail occurs for country code?
What are the reasons for p2p fail is generated from by changing the code from JP to KR?
system is
model: rpi 3b+
install: noobs 1.9.1 rasbian
uname -a
inux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
dmesg
dmesg | grep brcmf
[    3.963631] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[    3.964315] usbcore: registered new interface driver brcmfmac
[    4.146591] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[    4.168790] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    4.391699] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    5.198319] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    5.198328] brcmfmac: brcmf_add_if: ignore IF event
[    5.202516] brcmfmac: power management disabled
[    7.121509] brcmfmac: brcmf_link_down: WLC_DISASSOC failed (-52)
[    7.140711] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
thanks for the help!
glynhudson
Re: RPI3 wifi connection issue (or country code setting)
Sat Jun 23, 2018 2:31 pm
I think I've also got the same issue:
<3>CTRL-EVENT-SSID-REENABLED id=0 ssid="OpenEnergyMonitor"
<3>Trying to associate with 64:66:b3:3a:c1:1f (SSID='test' freq=2437 MHz)
<3>Associated with 64:66:b3:3a:c1:1f
<4>WPA: Invalid EAPOL-Key MIC when using TPTK - ignoring TPTK
<4>WPA: Could not verify EAPOL-Key MIC - dropping packet
<3>Authentication with 64:66:b3:3a:c1:1f timed out.
<3>CTRL-EVENT-DISCONNECTED bssid=64:66:b3:3a:c1:1f reason=3 locally_generated=1
<3>WPA: 4-Way Handshake failed - pre-shared key may be incorrect
<3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="test" auth_failures=5 duration=75 reason=WRONG_KEY
<3>CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="test" auth_failures=6 duration=143 reason=CONN_FAILED
<3>CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=GB
The key is correct since it was previously connected to this network.
Who is online
Users browsing this forum: ejolson and 68 guests
