primr
Contact: AOL
RTC support
Wed May 25, 2016 6:42 pm
How do I setup up RTC for the Raspberrypi?
I have the RTC module
Rich Prim
Jednorozec
Re: RTC support
Wed May 25, 2016 6:55 pm
I hate it when all of the search engines are down.
http://www.raspberrypi-spy.co.uk/2015/0 ... pberry-pi/
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
gordon77
Re: RTC support
Wed May 25, 2016 7:16 pm
I think the above link will work for wheezy but not Jessie.
Here's what I did with my ds1307, l found it on this forum somewhere.
add dtoverlay=i2c-rtc,ds1307 to /boot/config.txt
in /lib/udev/hwclock-set put # in front of these lines
if [-e /run/systemd/system ]; then
exit
fi
and the 2 lines containing --systz
reboot your pi
set the clock with sudo date -s "9 jan 2016 09:12:00"
using the correct date and time
sudo hwclock -w
sudo hwclock -r
blaablaaguy
Re: RTC support
Wed May 25, 2016 7:38 pm
primr wrote:How do I setup up RTC for the Raspberrypi?
Rich Prim
Model number?
This signature intentionally left blank.
primr
Contact: AOL
Re: RTC support
Wed May 25, 2016 8:09 pm
Thank you, I will try your procedure.
Rich Prim
geoffr
Re: RTC support
Wed May 25, 2016 9:50 pm
There was a recent post where someone had put together a service using systemd:
viewtopic.php?f=63&t=147450&p=970370&hi ... ub#p970370
I haven't looked at this one yet, but it certainly looks worth a glance.
DirkS
Re: RTC support
Thu May 26, 2016 1:54 am
geoffr wrote:There was a recent post where someone had put together a service using systemd:
It really adds nothing. Or I should say: it adds too much.
Make sure you read all the comments.
