raspberry pi controlled li-ion battery charger
Posted: Sun May 22, 2016 1:53 pm
by anniq91
hello everyone. I've been doing project raspberry pi controlled li-ion battery charger.From the figure attached,digital pin 9 connect to GPIO 5 while analog 0 and 1 connect to GPIO 18 and GPIO 13 at the raspberry pi model B.Can someone give me an idea how to monitor the circuit;the current and voltage
Re: raspberry pi controlled li-ion battery charger
Posted: Sun May 22, 2016 2:43 pm
by Burngate
The Pi has no analogue inputs, so connecting those Analog pins won't help you.
Is this a ready-made charger board that you want to connect, or one you're making yourself?
Posted: Sun May 22, 2016 4:55 pm
by alexeames
I really wouldn't recommend anyone build a lithium cell battery charger unless they really know what they are doing.
Posted: Mon May 23, 2016 5:56 pm
by anniq91
a ready-made charger board.is there any way how im going to control the charging current using raspberry pi?
Posted: Mon May 23, 2016 11:36 pm
by masa-aud
reply to anniq91 on raspberry pi controlled li-ion
I think that you need to refer data sheets and should know about very voltage sensitive characteristics of such battery prior to "how to control by RPi". So you will find necessary to involve precision analog circuit just fixed for each brand and type of battery if you think to have a good system.
masa
Posted: Tue May 24, 2016 10:01 am
by Burngate
If it's a ready-made board it aught to be a lot more complicated than that. As alexeames says, Li-ion batteries need very carefull handling - not a diy project.
And, no, you're unlikely to be able to control it with a Pi.
Posted: Tue May 24, 2016 10:52 am
by Heater
anniq91,
I would strong advise against trying to build a li-ion battery charger. Charging such a battery is a complicated process. it has a constant current and constant voltage phase. It requires accurate measurement of voltage and current.
See "Charge and discharge procedure" here: https://en.wikipedia.org/wiki/Lithium-i ... _discharge
Note the statement "Failure to follow current and voltage limitations can result in an explosion."
It would also be wise to monitor battery temperature whilst charging. See notes on temperature in the above link.
Apart from all that there are ready made, working out of the box, charger boards available, with proper control chips on them. They are very cheap. Probably cheaper than building your own.
If, despite all that, you really, really want to build your own charger then a Pi is not an appropriate device to control it.
Posted: Tue May 24, 2016 12:47 pm
by pksato
If is a single cell, use TP4056 module. Cost less that US$1,00 on ebay.
Not have bus to connect to raspberry pi, but two led output can easy connect to RPi.
Some of these modules are pins to output, other no.
