vk4tec
ftp
Fri May 20, 2016 8:00 am
I am using ftp into Pi
Using pi and raspberry
Why do I get permission denied to a put BIN
Andrew
vk4tec
Re: ftp
Fri May 20, 2016 8:02 am
As does mkdir
Re: ftp
Fri May 20, 2016 8:20 am
Presumably use pi does not have permission to write wherever FTP is trying to put those files.
Suggest using SCP instead.
tweak42
Re: ftp
Fri May 20, 2016 8:25 am
vk4tec wrote:I am using ftp into Pi
Andrew
I believe write permissions are disabled by default since FTP is a insecure protocol. There's a .conf file in the /etc/ directory you'll have to edit to allow write access. The name depends on which ftp server you are using.
If you have ssh working you should be able to sftp, which works just like ftp and is secure.
vk4tec
Re: ftp
Fri May 20, 2016 10:28 pm
found it
/etc/.vsftpd.conf
write enable was turned off
Andrew
Re: ftp
Fri May 20, 2016 10:47 pm
The question is: Why do you want to use FTP? And especially have it write enabled?
Better to leave it disabled, better to remove the FTP server altogether.
FTP is not secure.
java
Re: ftp
Sat May 21, 2016 7:46 am
FTP is not secure, yes, but there have been lots less exploits against it, than other supposedly more secure services. Also if you limit the size of your upload directory, in my case, a 256 megabyte USB drive, it is not going to be any use to the warez types ... , nor most other folks wanting to abuse your FTP server.
If you want to keep data secure, the last place you store it is on a computer.
ej3-martin
Re: ftp
Sat May 21, 2016 7:57 am
I am not an expert on this, but I have used FTP on the pi, but swapped he protocol over to SFTP, I was able to browse all directories on my pi - details here -> https://www.raspberrypi.org/documentati ... sh/sftp.md
java
Re: ftp
Sat May 21, 2016 8:10 am
FTP "jails" have been available and in use for ages ...
