Multiple cameras on a single raspberry pi
Posted: Wed May 18, 2016 5:06 am
by amin137398
hi
can u guys help me with this?
I have a raspberry pi 2 B and I want to run 2 cameras with it . ( one using default flat camera port on the board and the other using USB port )
is this possible? can the CPU handle such a thing?
if yes , how? what do I need to do?
thanks
Re: Multiple cameras on a single raspberry pi
Posted: Wed May 18, 2016 10:00 am
by MarkR
It's possible to add multiple USB cameras, with suitable hubs, although you won't be able to stream video from them all at once because the bus has a limited speed.
The Pi camera doesn't use the USB and you can nominally only connect one camera using the CSI connector on the Pis (except the compute-module which supports two).
However, I think there may be some unofficial third party multiplexing boards for the Pi camera. These won't allow you to run >1 Pi camera at once, but you can switch between several cameras in software, with a suitable delay (maybe >1 second) while a different camera wakes up.
Posted: Wed May 18, 2016 10:17 am
by shuckle
I am streaming both the raspberry camera and also USB camera.
But indeed the ethernet is bottle neck and I have set both to 5 fps only.
I use motion to stream the USB cam and it uses the CPU heavily. Rapberry camera is mainly hardware thing and only uses the network.
Posted: Wed May 18, 2016 10:46 am
by ceteras
Posted: Fri May 20, 2016 2:53 pm
by amin137398
thanks
so the best way is to somehow switch between 2 cameras
Posted: Fri May 20, 2016 3:15 pm
by 6by9
amin137398 wrote:thanks
One Pi Camera and one USB camera will work fine if that achieves your aims.
The USB camera is unlikely to be able to use any GPU processing/encoding as they spit out a format that can't easily be consumed (YUYV). It depends what you want to do with the data.
The switcher was mentioned as an alternative if you wanted two identical cameras, or use the Compute Module which has both camera interfaces of the SoC exposed.
Posted: Sat May 21, 2016 8:32 am
by amin137398
ohhh thanks that's helpful
I want to do image processing ( at least on 1 of the cameras ) , and then display both images from the cameras on 1 LCD simultaneously
something like this :
Posted: Sat May 21, 2016 10:26 am
by PiGraham
amin137398 wrote:I want to do image processing ( at least on 1 of the cameras ) , and then display both images from the cameras on 1 LCD simultaneously
Yes, you can do that. Two USB cameras, or a Pi cam + a USB cam. Here is some pygame code that displays two cameras PIP as your drawing:
#Python 2.7.9
import sys
import pygame
import pygame.camera
import datetime as dt
import time
pygame.init()
pygame.camera.init()
change_channel = False
channel = 0
changeover_time = 5
Run = True
#create display
screen = pygame.display.set_mode((1240,768),0)
pygame.font.init()
ovl_font = pygame.font.Font(None,30)
label1 = ovl_font.render('Camera 1', True,(255,255,255),(0,0,0))
label2 = ovl_font.render('Camera 2', True,(255,255,255),(0,0,0))
#find, open and start low-res camera
cam_list = pygame.camera.list_cameras()
webcam1 = pygame.camera.Camera(cam_list[0],(1024,768))
webcam2 = pygame.camera.Camera(cam_list[1],(320,240))
#webcam = pygame.camera.Camera(cam_list[channel],(1280,720))
#If no cameras found then nothing to do, quit
if(len(cam_list)==0):
    pygame.quit()
    sys.exit()
webcam1.start()
webcam2.start()
#webcam.start()
while Run:
     time.sleep(0.01)
    #grab image, scale and blit to screen
    imagen1 = webcam1.get_image()
    imagen2 = webcam2.get_image()
    #imagen = webcam.get_image()
     #imagen = pygame.transform.scale(imagen,(1920,1080))
    screen.blit(imagen1,(0,0))
    screen.blit(imagen2,(0,0))
    screen.blit(label1,(imagen1.get_width()-label1.get_width()-10,imagen1.get_height() - label1.get_height() - 10))
    screen.blit(label2,(imagen2.get_width() - label2.get_width() - 10,imagen2.get_height() - label2.get_height() - 10))
    #draw all updates to display
    pygame.display.update()
    # check for events ESC key quits
    for event in pygame.event.get():
        if event.type == pygame.KEYDOWN:
            if event.key == pygame.K_ESCAPE:
                Run = False
                webcam1.stop()
                webcam2.stop()
Rough code to show the principle. Requires error checking, handling variations between cameras etc etc. It works for me on Pi3B with a Philips SPC900NC and a Logitech B525 HD Webcam.
Also works with Pi Camera (V1) as one of the cameras. Make sure V4l2 driver is running:
sudo modprobe bcm2835-v4l2
CHeck you have two video devices listed:
ls /dev/vid*
You should get
/dev/video0 /dev/video1
Frame rate isn't full 30 fps (maybe 15 - 20 fps) . CPU load is ~60%.
I expect there are lots of optimisations that can be done. Not least avoid getting images sequentially from two unsynchronised cameras.
Posted: Sat May 21, 2016 12:40 pm
by amin137398
PiGraham wrote: Yes, you can do that. Two USB cameras, or a Pi cam + a USB cam. Here is some pygame code that displays two cameras PIP as your drawing:
#Python 2.7.9
import sys
import pygame
import time
pygame.init()
channel = 0
changeover_time = 5
Run = True
#create display
pygame.font.init()
    pygame.quit()
    sys.exit()
webcam1.start()
webcam2.start()
#webcam.start()
while Run:
     time.sleep(0.01)
                Run = False
                webcam1.stop()
                webcam2.stop()
thanks
I'm going to do it and keep you guys posted and share the result soon .
Posted: Mon May 23, 2016 11:46 am
by amin137398
I can use 2 USB camera , can I?
Posted: Mon May 23, 2016 12:22 pm
by shuckle
Yes, in theory. Depending on details you may have issues with CPU power, but yes, basically it is possible to use 2 USB cameras.
Posted: Mon May 23, 2016 2:00 pm
by PiGraham
amin137398 wrote:I can use 2 USB camera , can I?
Didn't you actually read my post above where I confirmed using two USB cameras?
Posted: Mon May 23, 2016 4:49 pm
by PiGraham
Tweaked code seems to run better.
Only reads an image from a camera when there is one available, so should avoid sequential blocking calls to get_image().
Uses double buffering and HW rendering
Added FPS info. Reports 10 to 15 fps. Seems more consistent.
CPU load still fairly high, 60 - 75%.
import sys
import pygame
import time
import datetime
pygame.init()
channel = 0
Run = True
newimg = False
current = datetime.datetime.now()
last = current
framerate = 0
iir_filter = 0.95
#create display
#screen = pygame.display.set_mode((1024,768),pygame.DOUBLEBUF|pygame.HWSURFACE|pygame.FULLSCREEN)
screen = pygame.display.set_mode((1024,768),pygame.HWSURFACE|pygame.DOUBLEBUF)
pygame.font.init()
fps = ovl_font.render('FPS:', True,(255,255,255),(0,0,0))
    pygame.quit()
    sys.exit()
webcam1.start()
webcam2.start()
#webcam.start()
while Run:
    time.sleep(0.01)
    if webcam1.query_image():
        newimg = True
    if webcam2.query_image():
        #newimg = True
    if newimg:
        newimg = False
        framerate = iir_filter * (1/(current - last).total_seconds()) + (1.0 - iir_filter)  * framerate	# iir filter value
        last = current
        fps = ovl_font.render("FPS: %r" % round(framerate,1) , True,(255,255,255),(0,0,0))
        screen.blit(fps,(imagen1.get_width() - fps.get_width() - 10,10))
        pygame.display.flip()
                Run = False
                webcam1.stop()
                webcam2.stop()
Posted: Wed May 25, 2016 8:34 am
by amin137398
oh sorry
I just didn't pay attention :)
