ThomasDr
Best way to Power a Pi3 without USB?
Tue May 17, 2016 10:59 am
Hallo,
Where is the best place to supplied a Rpi 3 with power, when i not use the micro USB?
Over the GPIO or solder parallel to D5?
regards
Thomas
darkbibble
Re: Best way to Power a Pi3 without USB?
Tue May 17, 2016 12:10 pm
you can power the pi via GPIO by connecting to the +5v and the grnd pins, BUT this can be risky as it bypasses the pi safety fuse.
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
klricks
Tue May 17, 2016 1:00 pm
ThomasDr wrote:Hallo,
regards
Thomas
Solder +5V to test pad PP1 or PP2 or to fuse pad closest to the edge of the board. Any of these 3 points are before the fuse ....same as using micro USB. (D5 or GPIO is after the fuse).
For Ground I would use any of the port shield hold down tabs on the bottom of the board. RJ45..HDMI etc.
davenull
Tue May 17, 2016 2:42 pm
hello,
just out of interest:
what and where is PP1 or PP2 ?
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
Mandrewpi
Tue May 17, 2016 2:50 pm
davenull wrote:hello,
They are labeled on the back side of the board under the micro usb input.
A computer is only as smart as its programmer. ;)
I own:
Pi B rev.2, Pi 2 B, Two Pi 3 B, Two Pi 3 b+, Pi 4 2Gb, Pi Zero 1.2, Pi Zero 1.3, Two Pi Zero Ws.
I'm known elsewhere as mandrew1444
davenull
Tue May 17, 2016 2:55 pm
aha, thank you!
