Page 1 of 4
13th May 2016 Changes to the Raspbian Jessie Desktop
Posted: Fri May 13, 2016 8:32 am
by fruitoftheloom
13th May 2016
https://www.raspberrypi.org/blog/anothe ... e-raspbian
Main highlights:
Bluetooth
SD Card Copier
Linux Kernel 4.4
Re: 13th May 2016 Changes to the Raspbian Jessie Desktop
Posted: Fri May 13, 2016 8:36 am
by Fidelius
Is the new Raspbian image already on the download page? I only see the older Raspbian image from March 2016.
Same with
sudo apt-get update
sudo apt-get dist-upgrade
… list zero updates for me so far.
Is there a command to see if the Pi runs the recent Jessie? I know "uname -a", however it lists the kernel (4.1.19-v7) but not the word "Jessie". :-)
Posted: Fri May 13, 2016 8:57 am
by fruitoftheloom
Fidelius wrote:Is the new Raspbian image already on the download page? I only see the older Raspbian image from March 2016.
Same with
sudo apt-get update
https://www.raspberrypi.org/downloads/raspbian
RASPBIAN JESSIE
Full desktop image based on Debian Jessie
Version:May 2016
Release date:2016-05-10
Kernel version:4.4
Posted: Fri May 13, 2016 9:03 am
by B.Goode
Kudos, congratulations and thanks to @joan, a regular contributor here, for the inclusion of the pigpio library.
Posted: Fri May 13, 2016 9:06 am
by Fidelius
Thanks Fruitoftheloom, now the download page does allow to download the new version indeed.
Anybody already did an "sudo apt-get dist-upgrade" ?
Posted: Fri May 13, 2016 9:11 am
by DirkS
Fidelius wrote:Anybody already did an "sudo apt-get dist-upgrade" ?
Tried it, but the repo has not been updated yet.
Just try again later today or so.
Posted: Fri May 13, 2016 9:17 am
by Fidelius
DirkS, will do, thanks!
Posted: Fri May 13, 2016 9:22 am
by DirkS
Fidelius wrote:DirkS, will do, thanks!
See https://www.raspberrypi.org/blog/anothe ... nt-1258088
And they *have* caught up now :)
Posted: Fri May 13, 2016 9:23 am
by liz
I came here to post exactly that. :)
Posted: Fri May 13, 2016 9:38 am
by Forris
'unable to locate package piclone'
Have to try again later?
Posted: Fri May 13, 2016 9:45 am
by DirkS
Forris wrote:'unable to locate package piclone'
You have to run 'sudo apt-get update' first.
I just installed it, so it's available now.
Posted: Fri May 13, 2016 9:51 am
by DirkS
Apart from the desktop stuff there are some useful changes 'under the hood'.
Kernel + modules are split off from raspberrypi-bootloader into a separate package (raspberrypi-kernel)
And there is a new package with the kernel headers: raspberrypi-kernel-headers.
raspberrypi-bootloader now only contains bootcode.bin, start*.elf and fixup*.dat
Posted: Fri May 13, 2016 9:54 am
by Forris
Yes, I did that. The other 2 items installed ok, but not piclone (even tried it on it's own).
LIVE UPDATE: Done it now!
Posted: Fri May 13, 2016 10:04 am
by ShiftPlusOne
DirkS wrote:Apart from the desktop stuff there are some useful changes 'under the hood'.
Well spotted. The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.
Posted: Fri May 13, 2016 10:08 am
by B.Goode
Another real gem, tucked away at the end of the write-up:
When flashing a new Raspbian image, the file system will automatically be expanded to use all the space on the card when it is first booted.
Posted: Fri May 13, 2016 10:21 am
by Fidelius
Is it possible to disable Wlan and Bluetooth on a Pi3 with this new Raspbian release?
Or do I still have to use the previous apporach which works well but is uneasy to handle:
/etc/modprobe.d/raspi-blacklist.conf
# Wlan
blacklist brcmfmac
blacklist brcmutil
# Bluetooth
blacklist btbcm
blacklist hci_uart
Posted: Fri May 13, 2016 10:27 am
by ghans
We have a raspberrypi-kernel-headers package now ?? :o
Posted: Fri May 13, 2016 10:32 am
by ShiftPlusOne
ghans wrote:We have a raspberrypi-kernel-headers package now ?? :o
Unfortunately, it has a huge number of files and dpkg will calculate an md5 digest for each of them, so it takes forever to install.
Posted: Fri May 13, 2016 11:05 am
by gregeric
ShiftPlusOne wrote:The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.
I googled that, it's a most welcome addition.
Posted: Fri May 13, 2016 11:09 am
by ShiftPlusOne
Note that raspberrypi-kernel-headers would need to be installed first. Otherwise, dkms will try to pull in the wrong headers package.
Posted: Fri May 13, 2016 11:47 am
by Rive
I am already running 4.4.9, is there an "apt-get install" just for the bt (replace blueman), and sd copier? I do not want to do a dist-upgrade.
Bluetooth
SD Card Copier
Posted: Fri May 13, 2016 11:53 am
by DirkS
Rive wrote:I am already running 4.4.9, is there an "apt-get install" just for the bt (replace blueman), and sd copier? I do not want to do a dist-upgrade.
I think you can do that with just update / upgrade and then install piclone
Posted: Fri May 13, 2016 12:05 pm
by ShiftPlusOne
Rive wrote:I do not want to do a dist-upgrade.
Why not exactly? The theme bug you reported a while bag has been fixed.
Posted: Fri May 13, 2016 12:26 pm
by Fidelius
When I "sudo poweroff" the Pi3, in contrast to former Raspbians the green (SD?) LED really turns off after some blinking, leaving only the red power LED on.
That's nice.
Posted: Fri May 13, 2016 12:42 pm
by Rive
I am on the rpi-update (4.4.9), is the dist-upgrade the exact same?
