13th May 2016 Changes to the Raspbian Jessie Desktop
Fri May 13, 2016 8:32 am
13th May 2016
https://www.raspberrypi.org/blog/anothe ... e-raspbian
Main highlights:
Bluetooth
SD Card Copier
Linux Kernel 4.4
RPi 4B 4GB (SSD Boot)..
Fidelius
Re: 13th May 2016 Changes to the Raspbian Jessie Desktop
Fri May 13, 2016 8:36 am
Is the new Raspbian image already on the download page? I only see the older Raspbian image from March 2016.
Same with
sudo apt-get update
sudo apt-get dist-upgrade
… list zero updates for me so far.
Is there a command to see if the Pi runs the recent Jessie? I know "uname -a", however it lists the kernel (4.1.19-v7) but not the word "Jessie". :-)
Fri May 13, 2016 8:57 am
Fidelius wrote:Is the new Raspbian image already on the download page? I only see the older Raspbian image from March 2016.
Same with
sudo apt-get update
https://www.raspberrypi.org/downloads/raspbian
RASPBIAN JESSIE
Full desktop image based on Debian Jessie
Version:May 2016
Release date:2016-05-10
Kernel version:4.4
B.Goode
Fri May 13, 2016 9:03 am
Kudos, congratulations and thanks to @joan, a regular contributor here, for the inclusion of the pigpio library.
Fidelius
Fri May 13, 2016 9:06 am
Thanks Fruitoftheloom, now the download page does allow to download the new version indeed.
Anybody already did an "sudo apt-get dist-upgrade" ?
DirkS
Fri May 13, 2016 9:11 am
Fidelius wrote:Anybody already did an "sudo apt-get dist-upgrade" ?
Tried it, but the repo has not been updated yet.
Just try again later today or so.
Fidelius
Fri May 13, 2016 9:17 am
DirkS, will do, thanks!
DirkS
Fri May 13, 2016 9:22 am
Fidelius wrote:DirkS, will do, thanks!
See https://www.raspberrypi.org/blog/anothe ... nt-1258088
And they *have* caught up now :)
liz
Raspberry Pi Foundation Employee & Forum Moderator
Fri May 13, 2016 9:23 am
I came here to post exactly that. :)
Director of Communications, Raspberry Pi
Forris
Raspberry Pi Certified Educator
Fri May 13, 2016 9:38 am
'unable to locate package piclone'
Have to try again later?
DirkS
Fri May 13, 2016 9:45 am
Forris wrote:'unable to locate package piclone'
You have to run 'sudo apt-get update' first.
I just installed it, so it's available now.
DirkS
Fri May 13, 2016 9:51 am
Apart from the desktop stuff there are some useful changes 'under the hood'.
Kernel + modules are split off from raspberrypi-bootloader into a separate package (raspberrypi-kernel)
And there is a new package with the kernel headers: raspberrypi-kernel-headers.
raspberrypi-bootloader now only contains bootcode.bin, start*.elf and fixup*.dat
Forris
Fri May 13, 2016 9:54 am
Yes, I did that. The other 2 items installed ok, but not piclone (even tried it on it's own).
LIVE UPDATE: Done it now!
ShiftPlusOne
Fri May 13, 2016 10:04 am
DirkS wrote:Apart from the desktop stuff there are some useful changes 'under the hood'.
Well spotted. The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.
B.Goode
Fri May 13, 2016 10:08 am
Another real gem, tucked away at the end of the write-up:
When flashing a new Raspbian image, the file system will automatically be expanded to use all the space on the card when it is first booted.
Fidelius
Fri May 13, 2016 10:21 am
Is it possible to disable Wlan and Bluetooth on a Pi3 with this new Raspbian release?
Or do I still have to use the previous apporach which works well but is uneasy to handle:
/etc/modprobe.d/raspi-blacklist.conf
# Wlan
blacklist brcmfmac
blacklist brcmutil
# Bluetooth
blacklist btbcm
blacklist hci_uart
ghans
Fri May 13, 2016 10:27 am
We have a raspberrypi-kernel-headers package now ?? :o
ShiftPlusOne
Fri May 13, 2016 10:32 am
ghans wrote:We have a raspberrypi-kernel-headers package now ?? :o
Unfortunately, it has a huge number of files and dpkg will calculate an md5 digest for each of them, so it takes forever to install.
gregeric
Fri May 13, 2016 11:05 am
ShiftPlusOne wrote:The kernel also works with dkms now, so out-of-tree modules are easy to keep up to date.
I googled that, it's a most welcome addition.
ShiftPlusOne
Fri May 13, 2016 11:09 am
Note that raspberrypi-kernel-headers would need to be installed first. Otherwise, dkms will try to pull in the wrong headers package.
Rive
Fri May 13, 2016 11:47 am
I am already running 4.4.9, is there an "apt-get install" just for the bt (replace blueman), and sd copier? I do not want to do a dist-upgrade.
Bluetooth
SD Card Copier
DNPNWO
DirkS
Fri May 13, 2016 11:53 am
Rive wrote:I am already running 4.4.9, is there an "apt-get install" just for the bt (replace blueman), and sd copier? I do not want to do a dist-upgrade.
I think you can do that with just update / upgrade and then install piclone
ShiftPlusOne
Fri May 13, 2016 12:05 pm
Rive wrote:I do not want to do a dist-upgrade.
Why not exactly? The theme bug you reported a while bag has been fixed.
Fidelius
Fri May 13, 2016 12:26 pm
When I "sudo poweroff" the Pi3, in contrast to former Raspbians the green (SD?) LED really turns off after some blinking, leaving only the red power LED on.
That's nice.
Rive
Fri May 13, 2016 12:42 pm
I am on the rpi-update (4.4.9), is the dist-upgrade the exact same?
DNPNWO
