Oxwivi
Re: A real situation
Fri Nov 25, 2011 5:54 am
I have a friend in Yemen who\'s in the limited situation that the R-Pi for developing countries are targetting. Due to political turmoil, he is limited to only two hours of electricity everyday. Even if R-Pi can run (I think I read it only needs 2 W) on your regular batteries, there are no display available.
Low-{cost,power} displays, anyone?
Bikko
Fri Nov 25, 2011 6:51 am
Best thing would be componant LCD displays.
Found this
http://www.amazon.co.uk/dp/B002U0K7HY/r ... B002U0K7HY
Just hook it up to a USB powerd hub
radu
Fri Nov 25, 2011 7:05 am
I think your friend would be better off buying a netbook and connecting it to a car battery.
Oxwivi
Fri Nov 25, 2011 7:09 am
[quote]Quote from Bikko on November 25, 2011, 06:51
http://www.amazon.co.uk/dp/B002U0K7HY/r ... B002U0K7HY [/quote]
At 121 British pounds, doesn\'t really fall into the cheap category.
eggn1n3
Fri Nov 25, 2011 7:30 am
But I guess he has a TV? So the composite output of the Raspberry Pi can be used.
Using a 12V to 220V adapter he can use some car batteries.
Asmodeus
Fri Nov 25, 2011 8:38 am
A portable travel TV?
I have a ROADSTAR LCD-2500/S PORTABLE TRAVEL TV 2.5\" LCD AV IN. Connected my Playstation2 via composite. Screen is ok, mono sound. Built-in battery charger (4xAAA). You could connect it to car battery. Paid 28,80€.
meltwater
Fri Nov 25, 2011 9:07 am
If he can wait, then perhaps see what happens with the CSI connector that may allow the right kind of LCD module to be connected without expensive drivers, thus keeping costs low and power required to a minimum.
Alternatively, if composite input is ok, try getting a low cost Reversing Screen, which would run directly from 12V car battery (price & power requirements verses size applies of course):
http://www.dealextreme.com/p/3-5-tft-lc ... -15v-49796
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
