Gerd
Re: Raspbian Jessie linux 4.4.9 Severe Performance Degradati
Wed May 11, 2016 8:05 pm
I cannot confirm a performace drop in 4.4.9 - as far as linpack is concened. Others untested.
3 runs of Linpack; N=10000; max=7,189 Gflops; max temp = 45°C
right order of the updates?
[email protected]:~ $ cat /proc/version
Linux version 4.4.9-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #884 SMP Fri May 6 17:28:59 BST 2016
[email protected]:~ $ ./xhpl
HPLinpack 2.1  --  High-Performance Linpack benchmark  --   October 26, 2012
Written by A. Petitet and R. Clint Whaley,  Innovative Computing Laboratory, UTK
Modified by Piotr Luszczek, Innovative Computing Laboratory, UTK
Modified by Julien Langou, University of Colorado Denver
An explanation of the input/output parameters follows:
T/V    : Wall time / encoded variant.
N      : The order of the coefficient matrix A.
NB     : The partitioning blocking factor.
P      : The number of process rows.
Q      : The number of process columns.
Time   : Time in seconds to solve the linear system.
Gflops : Rate of execution for solving the linear system.
The following parameter values will be used:
N      :   10000
NB     :     256
PMAP   : Row-major process mapping
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
SWAP   : Mix (threshold = 64)
L1     : transposed form
U      : transposed form
EQUIL  : yes
ALIGN  : 8 double precision words
- The matrix A is randomly generated for each test.
- The following scaled residual check will be computed:
      ||Ax-b||_oo / ( eps * ( || x ||_oo * || A ||_oo + || b ||_oo ) * N )
- The relative machine precision (eps) is taken to be               1.110223e-16
- Computational tests pass if scaled residuals are less than                16.0
T/V                N    NB     P     Q               Time                 Gflops
WR02R2L2       10000   256     1     1              94.83              7.032e+00
HPL_pdgesv() start time Wed May 11 21:31:50 2016
HPL_pdgesv() end time   Wed May 11 21:33:25 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)=        0.0023045 ...... PASSED
Finished      1 tests with the following results:
              1 tests completed and passed residual checks,
              0 tests completed and failed residual checks,
              0 tests skipped because of illegal input values.
End of Tests.
N      :   10000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2       10000   256     1     1              93.85              7.105e+00
HPL_pdgesv() start time Wed May 11 21:34:43 2016
HPL_pdgesv() end time   Wed May 11 21:36:17 2016
End of Tests.
N      :   10000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2       10000   256     1     1              92.75              7.189e+00
HPL_pdgesv() start time Wed May 11 21:44:23 2016
HPL_pdgesv() end time   Wed May 11 21:45:56 2016
End of Tests.
[email protected]:~ $ uname -a && vcgencmd version
Linux raspberrypi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
May  6 2016 13:53:23
Copyright (c) 2012 Broadcom
version 0cc642d53eab041e67c8c373d989fef5847448f8 (clean) (release)
Rive
Wed May 11, 2016 8:12 pm
Gerd wrote:I cannot confirm a performace drop in 4.4.9 - as far as linpack is concened. Others untested.
It isn't how high can you overclock, and what Gflop can you pass at on 4.4.9, it is a comparison between both kernels using the same benchmark parameters, config as a constant. ;)
Run it in 4.1.19 and 4.4.9 and give the following output for both kernels (while running the bench).
vmstat 2 -w
see: viewtopic.php?p=972268#p972268
DNPNWO
ejolson
Wed May 11, 2016 8:14 pm
Rive wrote:
ejolson wrote:
Rive wrote:I don't use turbo mode, and it isn't enabled in /boot/config.txt (except apparently by "sd_overclock' in 4.1.19). My governor is 'ondemand' in both kernels (idling at 600 MHz).
What happens if you set the CPU governor to performance in the 4.4.9 kernel?
I dunno. I am currently on 4.1.19 atm. But I assume it would always run at 1.26 Ghz, at around 55C ;) if all cores where maxed with Neon instructions.
That's what I think too. Maybe setting the governor to performance mode would also determine whether the slower speeds in the newer kernel is related to changes in the ondemand governor.
Unfortunately linpack results for N=10000 can't be directly compared to those for N=8000. Are you overclocking or setting the CPU governor to performance for your runs?
Gerd
Wed May 11, 2016 9:00 pm
Good point! Please find 3 runs of Linpack with N=8000 attached. max=6,861 Gflops. OC [email protected] [email protected]
Still I say: No performance degradation. In sync with earlier measures for 4.1. Compare: viewtopic.php?p=959556#p959556 where I replied to you.
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              49.76              6.861e+00
HPL_pdgesv() start time Wed May 11 22:20:33 2016
HPL_pdgesv() end time   Wed May 11 22:21:23 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)=        0.0025941 ...... PASSED
End of Tests.
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              50.72              6.732e+00
HPL_pdgesv() start time Wed May 11 22:21:56 2016
HPL_pdgesv() end time   Wed May 11 22:22:46 2016
End of Tests.
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              50.61              6.747e+00
HPL_pdgesv() start time Wed May 11 22:23:42 2016
HPL_pdgesv() end time   Wed May 11 22:24:32 2016
End of Tests.
dom
Wed May 11, 2016 9:21 pm
@Rive
does "dtoverlay=pi3-miniuart-bt" added to config.txt help the 4.4.9 performance?
We have spotted what looks like unwanted serial interrupts occurring, they stop when that overlay is applied. (enable_uart=1 also seems to fix it).
Rive
Wed May 11, 2016 9:24 pm
dom wrote:@Rive
I am currently back on 4.1, but I will rpi-update, and add that to the boot config and report back
DNPNWO
Gerd
Wed May 11, 2016 9:36 pm
I am using the following in config.txt, if that helps sorting out the problem:
#Overlay for disabling Bluetooth
dtoverlay=pi3-disable-bt
#no uart for Gerd
#see https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=141195
enable_uart=0
dom
Wed May 11, 2016 9:45 pm
Gerd wrote:I am using the following in config.txt, if that helps sorting out the problem:
Neither of those settings were the ones I suggested.
Run:
grep serial /proc/interrupts
 59:  114995416          0          0          0  ARMCTRL-level  61 Edge      serial
A large number after the ":" that increases rapidly is unwanted. If it is either not present of has a small stable number in, then that is okay.
Rive
Wed May 11, 2016 9:52 pm
It appears to have disabled Bluetooth...
No improvement in sdbench:
HDPARM 36.38 MB/s READ 35.33 MB/s WRITE 14.82 MB/s
Improvement in sybench (in line with 4.1.19 results): 114.3685s
Improvement in linpack bench (in line with 4.1.19 results): passed 6.697 Gflops
So does this mean that the BT is causing the degradation? What about the sd_overclock? No good anymore in 4.4.9?
[email protected]:~ $ vmstat 2 -w
procs ---------------memory-------------- ---swap-- -----io---- -system-- ------cpu-----
 r  b     swpd     free     buff    cache   si   so    bi    bo   in   cs us sy id wa st
 1  0        0   306920    31576   350468    0    0   964    28  353  429  9  4 84  3  0
 0  0        0   307068    31576   350508    0    0     0     0  970  729  4  2 93  0  0
 0  0        0   306944    31576   350508    0    0     0     0  857  575  1  1 98  0  0
 0  0        0   303288    31604   351248    0    0   380    75  982  920  4  2 94  1  0
 0  1        0   303288    31604   351248    0    0 15360     0  824  664  1  0 91  8  0
 0  1        0   303288    31604   351248    0    0 37888     0  767  621  1  1 74 24  0
 0  0        0   303660    31148   351248    0    0  7168     0  687  313  1  1 93  5  0
 1  0        0   303660    31148   351248    0    0  9216     0  733  361  1  0 93  6  0
 0  1        0   303660    31148   351248    0    0 36864     0  715  574  1  1 74 24  0
 1  0        0   303660    31148   351248    0    0  8192     0  634  273  1  2 92  6  0
 0  1        0   303652    31148   351248    0    0  8192     0  587  194  1  0 94  5  0
 0  1        0   303652    31148   351248    0    0 35840     0  671  520  1  1 74 24  0
 0  2        0   110156    31152   542592    0    0 10268 51250 1433 3312  1 12 73 14  0
 0  2        0    83244    31152   569004    0    0     0 15822  805  578  0  1 75 24  0
 0  1        0    75516    31172   576528    0    0     8  6662  752  536  0  1 74 24  0
 0  3        0    75548    31176   576636    0    0     0  4132  652  416  0  0 34 66  0
 0  3        0    75548    31176   576636    0    0     0     0  695  407  0  0 25 75  0
 0  2        0    60404    31192   591684    0    0     4 40980  712  433  1  3 44 52  0
 0  3        0    60404    31192   591688    0    0     0     0  762  544  0  0 25 74  0
 0  3        0    60404    31192   591688    0    0     0     0  651  355  1  0 25 74  0
 0  2        0    16696    30820   634036    0    0     2 33122  754  526  1  7 56 36  0
 0  3        0    16720    30820   634036    0    0     0     0  655  421  0  0 25 74  0
 0  3        0    16720    30820   634036    0    0     0     0  632  290  1  0 25 74  0
 0  2        0    14648    30832   635504    0    0     2  7904  673  299  1  1 27 72  0
 0  3        0    14736    30832   635484    0    0     0     0  638  218  0  0 50 50  0
 2  0        0    16696    30836   633408    0    0     0  2356  586  202  1  1 50 48  0
 0  2        0    16192    30844   633844    0    0     2 10256  953  551  1  1 72 26  0
 0  1        0    15812    30860   634220    0    0     6 24272  868  655  0  2 58 40  0
 0  1        0    17948    30868   632092    0    0     4 20492  648  350  0  6 73 21  0
 0  2        0    16128    30868   634264    0    0     0 15360  684  308  0  1 56 42  0
 0  2        0    16128    30868   634264    0    0     0     0  553  137  0  0 50 50  0
 0  4        0    16128    30872   634264    0    0     0  1050  630  344  1  0 50 50  0
 0  4        0    16128    30872   634264    0    0     0     0  593  295  1  0 49 50  0
 0  1        0    16288    30880   634272    0    0     2 28674 2536 3435  1  1 55 44  0
 1  0        0    16712    30888   634268    0    0    14    18 1428 1952  0  1 50 49  0
 1  2        0   179316    30908   473392    0    0    36 51820 2631 4169  1 13 70 17  0
 1  1        0   138688    30908   513408    0    0     0 24068  775  670  1  1 51 48  0
 0  3        0   111500    30912   540280    0    0     0 16406  767  697  0  1 50 48  0
 0  4        0   111532    30912   540280    0    0     0     0  635  353  0  1 25 74  0
 0  4        0   111596    30912   540280    0    0     0     0  633  390  0  0 25 74  0
 0  2        0    16492    30928   633796    0    0     2 50198  927  825  1  4 52 43  0
 0  2        0    16024    30928   633500    0    0     0 20492  928 2031  0  0 56 43  0
 0  2        0    16596    30936   632924    0    0     2 17428  992 1092  0  1 63 35  0
 0  3        0    16724    30936   632924    0    0     0     0  685  492  0  1 50 49  0
 0  2        0    16072    30940   633352    0    0     0 49158  770  657  1  4 50 45  0
 0  3        0    16476    30944   632816    0    0     0    14  714  579  1  1 30 68  0
 0  2        0    16568    30952   632808    0    0     2  8194 1152 1395  1  1  1 98  0
 0  2        0    16624    30956   632824    0    0     0 24592 1731 2602  1  2 63 34  0
 1  0        0   318716    30972   335888    0    0     0    72 1310 1579  1  7 37 55  0
 1  0        0   195268    30972   458516    0    0     0 55300  900  993  1  3 76 20  0
 1  0        0   156304    30976   497172    0    0     2 18436 1511 2059  0  2 72 26  0
 0  3        0   141028    30980   511736    0    0     0  8212  844  742  0  0 61 38  0
 0  4        0   141220    30980   511736    0    0     0     0 1106  521  1  0 25 74  0
 0  1        0    40520    30988   610732    0    0     2 49166  950  978  1  5 69 25  0
 0  2        0    39964    30992   610860    0    0     0  4110  636  456  0  1 51 47  0
 1  1        0    18872    30996   631408    0    0     0 42532  729  816  1  4 64 31  0
 0  1        0    16120    30996   634184    0    0     0  8166 1101  912  0  0 75 24  0
 0  4        0    16144    31000   634184    0    0     0  2574  805  480  0  0 41 58  0
 0  4        0    16176    31000   634184    0    0     0     0  561  220  0  1 25 74  0
 0  4        0    16176    31000   634184    0    0     0     0  569  229  0  0 25 74  0
 0  1        0    17788    31008   632184    0    0     2  8194  580  253  1  1 38 60  0
 3  1        0    15308    31016   634460    0    0     0  7724  583  273  0  1 46 53  0
 0  1        0    16004    31020   633072    0    0     2 57842 1225 1384  1  6 73 20  0
 0  1        0    16004    31020   633072    0    0     0     0  655  341  1  0 74 25  0
 0  2        0    16228    31028   633068    0    0     0    16  896  903  1  1 25 74  0
 0  2        0    16292    31028   633072    0    0     0     0 1222 1622  1  0 49 50  0
 0  1        0   614920      876    76116    0    0   414    32 1176 1515  0  7 55 38  0
 0  1        0   539396     1460   149980    0    0 37234    36 1497 2850  0  3 73 23  0
 0  1        0   468096     1460   221256    0    0 35648     0 1483 2704  1  3 74 23  0
 0  1        0   396672     1460   292700    0    0 35712     0 1522 2684  0  3 74 23  0
 1  0        0   325744     1468   363108    0    0 35200     8 1433 2620  1  4 72 23  0
 0  1        0   254784     1468   434140    0    0 35520     0 1542 2716  1  3 73 23  0
 0  1        0   183272     1468   505564    0    0 35712     0 1416 2608  1  3 73 23  0
 1  1        0   112752     1476   576012    0    0 35200     8 1560 2741  1  3 73 23  0
 1  0        0   578628     1192   111624    0    0 30820    38 1679 2763  1  7 72 20  0
 0  1        0   503236     1192   187212    0    0 37824     0 1140 2375  0  4 75 21  0
 0  1        0   431812     1192   258552    0    0 35712     0 1207 2372  1  4 74 21  0
 0  1        0   361256     1200   328972    0    0 35200     8 1170 2292  1  3 74 22  0
 0  1        0   290204     1200   400012    0    0 35520     0 1323 2483  1  3 75 22  0
 1  1        0   219444     1200   471424    0    0 35648     0 1451 2622  1  3 74 22  0
 0  1        0   148676     1208   541440    0    0 35072     8 1433 2618  1  3 73 23  0
 0  1        0   615676      632    76116    0    0 29990    22 1485 2502  1  6 73 20  0
 0  1        0   533668     1152   157076    0    0 40786    16 1399 2854  1  3 74 23  0
 0  1        0   461748     1484   228096    0    0 35686     0 1616 2781  1  4 73 22  0
 0  1        0   390820     1492   299000    0    0 35456     8 1685 2855  1  3 73 23  0
 0  1        0   319396     1492   370452    0    0 35712     0 1417 2616  1  3 73 23  0
 0  1        0   248220     1492   441620    0    0 35584     0 2077 3258  1  4 73 23  0
 1  0        0   177104     2248   511916    0    0 35576    10 1424 2581  1  3 74 23  0
 0  1        0   105344     2248   583644    0    0 35776     0 1403 2584  1  2 74 23  0
 0  0        0   613140     2844    77120    0    0  9152     0 1020 1154  1  5 88  6  0
 0  0        0   612768     2852    77120    0    0     0    38  650  219  0  0 99  0  0
 0  0        0   612768     2852    77120    0    0     0     0  575  123  1  0 99  0  0
 0  0        0   612768     2852    77120    0    0     0     0  585  141  1  0 99  0  0
 0  0        0   612768     2860    77120    0    0     0     8  557  108  0  0 99  0  0
 0  0        0   612768     2860    77120    0    0     0     0  618  172  1  0 99  0  0
 0  0        0   612768     2860    77120    0    0     0     0  666  244  1  0 99  0  0
 0  0        0   612768     2868    77124    0    0     0     8  571  122  1  0 99  0  0
 0  0        0   612768     2872    77124    0    0     2    38  565  143  1  0 99  0  0
 0  0        0   612768     2872    77124    0    0     0     0  578  133  1  0 99  0  0
 0  0        0   612768     2880    77124    0    0     0    12  558  108  1  0 99  0  0
 0  0        0   612768     2880    77124    0    0     0     0  566  111  1  0 99  0  0
 0  0        0   612768     2880    77124    0    0     0     0  652  229  0  0 99  0  0
 0  0        0   612768     3016    77144    0    0    64     8  585  145  1  0 99  0  0
 0  0        0   612900     3016    77124    0    0     0     0  594  151  1  0 99  0  0
 0  0        0   612908     3016    77124    0    0     0    10  580  140  1  0 99  0  0
 0  0        0   612924     3024    77124    0    0     0    18  571  124  1  0 99  0  0
 0  0        0   612800     3024    77124    0    0     0     0  662  240  1  0 99  0  0
 0  0        0   612800     3024    77124    0    0     0     0  607  170  1  0 99  0  0
 0  0        0   612800     3032    77124    0    0     0     8  593  194  1  0 99  0  0
 4  0        0   611660     3444    78044    0    0   644     0  883  711 17  0 82  1  0
 4  0        0   611008     3444    78000    0    0     0     0 1077  130 100  0  0  0  0
 4  0        0   611008     3452    78000    0    0     0     8 1056   96 100  0  0  0  0
 4  0        0   611008     3452    78000    0    0     0     0 1201  232 100  0  0  0  0
 4  0        0   611008     3452    78000    0    0     0     0 1092  137 100  0  0  0  0
 4  0        0   610636     3460    78000    0    0     0    12 1108  159 100  0  0  0  0
 4  0        0   610636     3460    78000    0    0     0     0 1152  204 100  0  0  0  0
 4  0        0   610512     3460    78000    0    0     0     0 1529  575 100  0  0  0  0
 4  0        0   610636     3468    78000    0    0     0    20 1367  447 99  1  0  0  0
 4  0        0   610140     3468    78000    0    0     0     0 1082  108 100  0  0  0  0
 4  0        0   610140     3468    78000    0    0     0     0 1104  155 100  0  0  0  0
 4  0        0   610140     3476    78000    0    0     0     8 1138  195 100  0  0  0  0
 4  0        0   610140     3476    78000    0    0     0     0 1073  109 100  0  0  0  0
 4  0        0   610140     3476    78000    0    0     0     0 1057  113 100  0  0  0  0
 4  0        0   610140     3484    78000    0    0     0     8 1194  242 100  0  0  0  0
 4  0        0   610140     3484    78000    0    0     0     0 1079  136 100  0  0  0  0
 4  0        0   610140     3484    78000    0    0     0     0 1099  155 100  0  0  0  0
 5  0        0   610140     3492    77992    0    0     0     8 1124  164 100  0  0  0  0
 4  0        0   610140     3492    78000    0    0     0     0 1055   91 100  0  0  0  0
 4  0        0   610140     3492    78000    0    0     0     0 1154  200 100  0  0  0  0
 4  0        0   610140     3500    77992    0    0     0     8 1057  103 100  0  0  0  0
 4  0        0   610140     3500    78000    0    0     0     0 1065   99 100  0  0  0  0
 4  0        0   610140     3500    78000    0    0     0     0 1068  123 100  0  0  0  0
 4  0        0   610140     3508    77992    0    0     0    12 1022   96 100  0  0  0  0
 4  0        0   610140     3508    78000    0    0     0     0 1051   80 100  0  0  0  0
 4  0        0   610140     3508    78000    0    0     0     4 1259  318 100  0  0  0  0
 4  0        0   610140     3516    77992    0    0     0     8 1039   85 100  0  0  0  0
 4  0        0   610140     3516    78000    0    0     0     0 1066  101 100  0  0  0  0
 4  0        0   610140     3516    78000    0    0     0     0 1056  105 100  0  0  0  0
 4  0        0   610140     3524    77996    0    0     0     8 1040   87 100  0  0  0  0
 4  0        0   610016     3524    78004    0    0     0     0 1174  212 100  0  0  0  0
 4  0        0   610016     3524    78004    0    0     0     0 1072  147 100  0  0  0  0
 4  0        0   610016     3532    77996    0    0     0     8 1103  153 100  0  0  0  0
 4  0        0   610016     3532    78004    0    0     0     0 1074  113 100  0  0  0  0
 4  0        0   610016     3532    78004    0    0     0     0 1039   89 100  0  0  0  0
 4  0        0   610016     3540    77996    0    0     0     8 1056  106 100  0  0  0  0
 4  0        0   610016     3540    78004    0    0     0     0 1157  192 100  0  0  0  0
 4  0        0   610092     3540    78004    0    0     0     0 1489  522 100  0  0  0  0
 5  0        0   610140     3548    77996    0    0     0    10 1232  312 100  0  0  0  0
 4  0        0   610140     3548    78004    0    0     0     0 1030   83 100  0  0  0  0
 4  0        0   610140     3552    78004    0    0     2     6 1073  150 100  0  0  0  0
 4  0        0   610140     3560    77996    0    0     0    12 1192  236 100  0  0  0  0
 4  0        0   610140     3560    78004    0    0     0     0 1046   81 100  0  0  0  0
 4  0        0   610140     3560    78004    0    0     0     6 1155  223 100  0  0  0  0
 4  0        0   610140     3568    77996    0    0     0     8 1054  102 100  0  0  0  0
 4  0        0   610140     3568    78004    0    0     0     0 1057  100 100  0  0  0  0
 4  0        0   610140     3568    78004    0    0     0     0 1038   90 100  0  0  0  0
 4  0        0   610140     3576    77996    0    0     0     8 1163  233 100  0  0  0  0
 4  0        0   610140     3576    78004    0    0     0     0 1075  118 100  0  0  0  0
 4  0        0   610140     3576    78004    0    0     0     0 1038   89 100  0  0  0  0
 4  0        0   610140     3584    77996    0    0     0     8 1064  118 100  0  0  0  0
 4  0        0   610140     3584    78004    0    0     0     0 1035   66 100  0  0  0  0
 4  0        0   610140     3584    78004    0    0     0     0 1234  282 100  0  0  0  0
 4  0        0   610140     3592    77996    0    0     0    10 1044   99 100  0  0  0  0
 4  0        0   610140     3592    78004    0    0     0     0 1060   89 100  0  0  0  0
 4  0        0   610140     3592    78004    0    0     0     0 1023   93 100  0  0  0  0
 4  0        0   610140     3600    77996    0    0     0     8 1050  108 100  0  0  0  0
 1  0        0   610116     3600    78004    0    0     0     0 1048   89 99  0  1  0  0
 0  0        0   610444     3600    78144    0    0    64     4  665  260  1  0 99  0  0
 1  0        0   610444     3608    78144    0    0     0    22  553   94  0  0 99  0  0
 0  0        0   610320     3608    78144    0    0     0    14  582  140  1  0 99  0  0
 0  0        0   610320     3608    78144    0    0     0     0  628  182  1  0 99  0  0
 0  0        0   610320     3616    78144    0    0     0     8  554  103  1  0 99  0  0
 0  0        0   610320     3616    78144    0    0     0     0  709  257  0  0 99  0  0
 0  0        0   610320     3616    78144    0    0     0     0  559  111  1  0 99  0  0
 0  0        0   610320     3624    78144    0    0     0     8  544   93  1  0 99  0  0
 0  0        0   610320     3624    78144    0    0     0     0  562  106  1  0 99  0  0
 0  0        0   610196     3624    78144    0    0     0     0  955  519  1  0 99  0  0
 0  0        0   610320     3632    78144    0    0     0    10  690  267  1  0 99  0  0
 0  0        0   610320     3632    78144    0    0     0     0  677  231  1  0 99  0  0
 0  0        0   610320     3632    78144    0    0     0     0  549  104  1  0 99  0  0
 0  0        0   610320     3640    78148    0    0     0     8  533   84  0  0 99  0  0
 0  0        0   610320     3640    78148    0    0     0     0  572  113  1  0 99  0  0
 0  0        0   610320     3640    78148    0    0     0     6  553  107  1  0 99  0  0
 0  0        0   610320     3648    78148    0    0     0    16  707  266  1  0 99  0  0
 0  0        0   610196     3656    78156    0    0     2     6  586  140  1  0 99  0  0
 0  0        0   610816     3656    78156    0    0     0     0  542   93  0  0 99  0  0
 0  0        0   610816     3664    78156    0    0     0    16  579  134  1  0 99  0  0
 0  0        0   610196     3664    78156    0    0     0    14  564  126  1  0 99  0  0
 0  0        0   610196     3664    78156    0    0     0     0  572  120  1  0 99  0  0
 1  0        0   610196     3672    78148    0    0     0     8  793  648  1  0 99  0  0
 1  0        0   586136     3944    80540    0    0  1326     0  744  535 10  8 81  1  0
 1  0        0   500028     3944    80548    0    0     0     0  681  139 24  2 74  0  0
 1  0        0   413228     3952    80540    0    0     0    22  640   96 23  2 75  0  0
 1  0        0   326428     3952    80548    0    0     0     0  622   71 24  2 75  0  0
 1  0        0   239380     3952    80548    0    0     0     0  746  213 23  3 74  0  0
 1  0        0   152332     3960    80540    0    0     0     8  630   90 24  2 74  0  0
 4  0        0    99764     3960    80640    0    0    46     0  793  130 48 12 40  0  0
 4  0        0    99144     3960    80640    0    0     0     0  911   94 99  0  1  0  0
 4  0        0    99144     3968    80632    0    0     0     8  925  103 89 11  0  0  0
 4  0        0    99144     3968    80640    0    0     0     0  910   82 98  1  0  0  0
 4  0        0    99144     3968    80640    0    0     0     0 1011  208 96  4  0  0  0
 4  0        0    99144     3976    80640    0    0     0     8  929  112 94  7  0  0  0
 4  0        0    99020     3976    80640    0    0     0     4  929  102 94  6  0  0  0
 4  0        0    99020     3976    80640    0    0     0     0  928  118 96  5  0  0  0
 4  0        0    99020     3984    80640    0    0     0     8  917  101 91  9  0  0  0
 4  0        0    99020     3984    80640    0    0     0     0 1025  197 100  0  0  0  0
 5  0        0    98896     3984    80640    0    0     0     0 1367  568 91  9  0  0  0
 4  0        0    99028     3992    80640    0    0     0    34 1061  326 100  0  0  0  0
 4  0        0    99028     3992    80640    0    0     0     0  931   90 91  9  0  0  0
 4  0        0    99028     3992    80640    0    0     0     0  935  116 90 11  0  0  0
 5  0        0    99028     4000    80640    0    0     0     8  944  119 95  5  0  0  0
 4  0        0    99028     4000    80640    0    0     0     0 1001  179 96  4  0  0  0
 4  0        0    99028     4000    80640    0    0     0     0  922  113 92  8  0  0  0
 4  0        0    99028     4008    80632    0    0     0     8  914   92 93  7  0  0  0
 4  0        0    99028     4008    80640    0    0     0     0  930  110 93  8  0  0  0
 5  0        0    99028     4008    80640    0    0     0     0  916  103 93  7  0  0  0
 5  0        0    99028     4016    80632    0    0     0     8  996  194 93  7  0  0  0
 5  0        0    99028     4016    80640    0    0     0     0  951  115 88 13  0  0  0
 7  0        0    99028     4016    80640    0    0     0     0  955  144 94  7  0  0  0
 5  0        0    99028     4024    80632    0    0     0    12  999  189 91  9  0  0  0
 5  0        0    99028     4024    80640    0    0     0     0  965  136 86 14  0  0  0
 4  0        0    99028     4024    80640    0    0     0     0  959  151 79 21  0  0  0
 1  0        0    98904     4032    80648    0    0     2    12  831  265 29  7 64  0  0
 1  0        0    98904     4032    80648    0    0     0     0  675  126 25  0 75  0  0
 1  0        0    98904     4032    80648    0    0     0     8  662  134 25  0 74  0  0
 1  0        0    98904     4040    80640    0    0     0     8  692  153 25  0 75  0  0
 1  0        0    98904     4040    80648    0    0     0     0  643   79 25  0 74  0  0
 5  0        0    98904     4040    80648    0    0     0     0  810  227 33  0 67  0  0
 0  0        0   607724     4048    80760    0    0    56    10  667  231 10  4 85  0  0
 0  0        0   607104     4048    80760    0    0     0     0  539   71  1  0 99  0  0
 0  0        0   607228     4048    80760    0    0     0     0  560   95  0  0 99  0  0
 1  0        0   607228     4056    80760    0    0     0     8  571  112  1  0 99  0  0
 0  0        0   607228     4056    80760    0    0     0     0  559   98  0  0 99  0  0
 0  0        0   607228     4056    80760    0    0     0     0  676  237  1  0 99  0  0
 0  0        0   607228     4064    80760    0    0     0     8  574  125  1  0 99  0  0
 0  0        0   607228     4064    80760    0    0     0     0  562  103  1  0 99  0  0
 0  0        0   607104     4064    80760    0    0     0     0  916  495  1  0 99  0  0
 0  0        0   607104     4072    80752    0    0     0    26  719  312  1  0 99  0  0
 0  0        0   607104     4072    80760    0    0     0     0  652  201  1  0 99  0  0
 0  0        0   607128     4072    80760    0    0     0     0  565  122  1  0 99  0  0
 0  0        0   607128     4080    80752    0    0     0     8  682  486  1  1 98  0  0
 1  0
[email protected]:~ $ sudo ./sdbench.sh
[3;J
CONFIG:
CLOCK : 100.000 MHz
CORE  : 500 MHz, turbo=0
DATA  : 512 MB, /root/test.dat
HDPARM:
 Timing O_DIRECT disk reads: 118 MB in  3.05 seconds =  38.63 MB/sec
 Timing O_DIRECT disk reads: 106 MB in  3.01 seconds =  35.18 MB/sec
 Timing O_DIRECT disk reads: 106 MB in  3.01 seconds =  35.21 MB/sec
WRITE:
536870912 bytes (537 MB) copied, 45.3008 s, 11.9 MB/s
536870912 bytes (537 MB) copied, 27.2186 s, 19.7 MB/s
536870912 bytes (537 MB) copied, 35.7013 s, 15.0 MB/s
READ:
536870912 bytes (537 MB) copied, 14.4903 s, 37.1 MB/s
536870912 bytes (537 MB) copied, 14.5179 s, 37.0 MB/s
536870912 bytes (537 MB) copied, 14.4658 s, 37.1 MB/s
RESULT (AVG):
Overlay config                      core_freq   turbo   overclock_50    WRITE        READ        HDPARM
                                       500        0     100.000 MHz   14.82 MB/s   35.33 MB/s   36.38 MB/s
[email protected]:~ $ sysbench --num-threads=4 --test=cpu --cpu-max-prime=20000 --validate run
sysbench 0.4.12:  multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 4
Additional request validation enabled.
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
    total time:                          114.3685s
    total number of events:              10000
    total time taken by event execution: 457.3140
    per-request statistics:
         min:                                 45.42ms
         avg:                                 45.73ms
         max:                                109.48ms
         approx.  95 percentile:              46.16ms
Threads fairness:
    events (avg/stddev):           2500.0000/14.30
    execution time (avg/stddev):   114.3285/0.02
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              50.98              6.697e+00
HPL_pdgesv() start time Wed May 11 17:49:48 2016
HPL_pdgesv() end time   Wed May 11 17:50:39 2016
End of Tests.
DNPNWO
Gerd
Wed May 11, 2016 10:03 pm
Well, there is no serial in interrupts
[email protected]:/proc $ cat interrupts
           CPU0       CPU1       CPU2       CPU3
 16:          0          0          0          0  bcm2836-timer   0 Edge      arch_timer
 17:    2170544   12074731    2067527    8279638  bcm2836-timer   1 Edge      arch_timer
 23:       5299          0          0          0  ARMCTRL-level   1 Edge      3f00b880.mailbox
 24:       4190          0          0          0  ARMCTRL-level   2 Edge      VCHIQ doorbell
 39:          1          0          0          0  ARMCTRL-level  41 Edge
 46:          0          0          0          0  ARMCTRL-level  48 Edge      bcm2708_fb dma
 48:      13864          0          0          0  ARMCTRL-level  50 Edge      DMA IRQ
 50:          0          0          0          0  ARMCTRL-level  52 Edge      DMA IRQ
 62:  103439540          0          0          0  ARMCTRL-level  64 Edge      dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
 79:          0          0          0          0  ARMCTRL-level  81 Edge      3f200000.gpio:bank0
 80:          0          0          0          0  ARMCTRL-level  82 Edge      3f200000.gpio:bank1
 86:       5470          0          0          0  ARMCTRL-level  88 Edge      mmc0
 87:          7          0          0          0  ARMCTRL-level  89 Edge      uart-pl011
 92:        456          0          0          0  ARMCTRL-level  94 Edge      mmc1
FIQ:              usb_fiq
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:      39490      72607      88617      67434  Rescheduling interrupts
IPI3:          6          7          8          8  Function call interrupts
IPI4:          3          5          0          5  Single function call interrupts
IPI5:          0          0          0          0  CPU stop interrupts
IPI6:          1          0          1          0  IRQ work interrupts
IPI7:          0          0          0          0  completion interrupts
Err:          0
           CPU0       CPU1       CPU2       CPU3
 17:    2170704   12075670    2067688    8279681  bcm2836-timer   1 Edge      arch_timer
 48:      13871          0          0          0  ARMCTRL-level  50 Edge      DMA IRQ
 62:  103446372          0          0          0  ARMCTRL-level  64 Edge      dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
 86:       5477          0          0          0  ARMCTRL-level  88 Edge      mmc0
FIQ:              usb_fiq
IPI2:      39539      72613      88666      67442  Rescheduling interrupts
Err:          0
           CPU0       CPU1       CPU2       CPU3
 17:    2170786   12077065    2067786    8279712  bcm2836-timer   1 Edge      arch_timer
 62:  103450311          0          0          0  ARMCTRL-level  64 Edge      dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
FIQ:              usb_fiq
IPI2:      39542      72618      88673      67450  Rescheduling interrupts
Err:          0
[email protected]:/proc $ grep serial /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
 17:    2175417   12085709    2073516    8284252  bcm2836-timer   1 Edge      arch_timer
 23:       5300          0          0          0  ARMCTRL-level   1 Edge      3f00b880.mailbox
 62:  103466650          0          0          0  ARMCTRL-level  64 Edge      dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
FIQ:              usb_fiq
IPI2:      39594      72650      88739      67481  Rescheduling interrupts
Err:          0
           CPU0       CPU1       CPU2       CPU3
 17:    2175973   12087826    2074605    8284783  bcm2836-timer   1 Edge      arch_timer
 62:  103469549          0          0          0  ARMCTRL-level  64 Edge      dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
FIQ:              usb_fiq
IPI2:      39596      72659      88743      67488  Rescheduling interrupts
Err:          0
           CPU0       CPU1       CPU2       CPU3
 17:    2176142   12091121    2075384    8284897  bcm2836-timer   1 Edge      arch_timer
 23:       5301          0          0          0  ARMCTRL-level   1 Edge      3f00b880.mailbox
 62:  103475610          0          0          0  ARMCTRL-level  64 Edge      dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
FIQ:              usb_fiq
IPI2:      39605      72668      88752      67511  Rescheduling interrupts
Err:          0
vmstat
 2  0        0   795228     6812   102936    0    0     0     0   27    6  0  0 100  0  0
 0  0        0   795204     6812   102936    0    0     0     0  285   38  0  0 100  0  0
 0  0        0   795204     6812   102936    0    0     0     0  272   20  0  0 100  0  0
 0  0        0   795252     6812   102936    0    0     0     0  281   40  0  0 100  0  0
 0  0        0   795252     6812   102936    0    0     0     0  275   28  0  0 100  0  0
 0  0        0   795252     6812   102936    0    0     0     0  272   22  0  0 100  0  0
 0  0        0   795252     6812   102936    0    0     0     0  277   29  0  0 100  0  0
 1  0        0   795252     6812   102936    0    0     0     0  288   54  0  0 100  0  0
 0  0        0   795056     6812   103084    0    0    86     0  294   60  0  0 100  0  0
 0  0        0   795112     6812   103108    0    0     0     0  697   23  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  271   23  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  479   21  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  270   21  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  270   23  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  276   28  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  273   24  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  270   20  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  272   21  0  0 100  0  0
 0  0        0   795088     6812   103108    0    0     0     0  273   27  0  0 100  0  0
 0  0        0   795088     6812   103108    0    0     0     0  273   24  0  0 100  0  0
 0  0        0   795088     6812   103108    0    0     0     0  271   21  0  0 100  0  0
 0  0        0   795120     6812   103108    0    0     0     0  755   83  0  0 100  0  0
 0  0        0   795104     6812   103108    0    0     0     0  287   45  0  0 100  0  0
 0  0        0   795120     6812   103108    0    0     0     0  277   32  0  0 100  0  0
 0  0        0   795120     6812   103108    0    0     0     0  275   29  0  0 100  0  0
 0  0        0   795088     6812   103108    0    0     0     0  274   27  0  0 100  0  0
 0  0        0   795096     6812   103108    0    0     0     0  481   30  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  275   31  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  714   34  0  0 100  0  0
 0  0        0   795096     6812   103108    0    0     0     0  277   30  0  0 100  0  0
 0  0        0   795128     6812   103108    0    0     0     0  276   32  0  0 100  0  0
 0  0        0   794988     6812   103108    0    0     0     0  291   50  0  0 100  0  0
 0  0        0   794956     6812   103108    0    0     0     0  273   20  0  0 100  0  0
 0  0        0   794972     6812   103108    0    0     0     0  284   46  0  0 100  0  0
 0  0        0   794940     6812   103108    0    0     0     0  296   68  0  0 100  0  0
 0  0        0   795004     6812   103108    0    0     0     0  279   31  0  0 100  0  0
 0  0        0   794972     6812   103108    0    0     0     0  285   48  0  0 100  0  0
 0  0        0   794832     6812   103108    0    0     0     0  739   58  0  0 100  0  0
 0  0        0   794956     6812   103108    0    0     0     0  306   68  0  0 100  0  0
 0  0        0   794956     6812   103108    0    0     0     0  485   23  0  0 100  0  0
 1  0        0   794988     6820   103108    0    0     0    16  289   58  0  0 100  0  0
 0  0        0   794972     6820   103108    0    0     0     0  305   65  0  0 100  0  0
 0  0        0   794988     6820   103108    0    0     0    12  300   85  0  0 100  0  0
 0  0        0   794988     6820   103108    0    0     0     0  284   46  0  0 100  0  0
 0  0        0   794768     6820   103108    0    0     0     0  319   77  0  0 99  0  0
 0  0        0   794864     6820   103108    0    0     0     0  274   26  0  0 100  0  0
 0  0        0   794864     6828   103100    0    0     0    16  277   35  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  270   18  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  277   26  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0    12  277   34  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  731   33  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  281   35  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  272   20  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  277   28  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  352  189  0  0 100  0  0
 0  0        0   794864     6828   103108    0    0     0     0  273   22  0  0 100  0  0
 0  0        0   794832     6828   103108    0    0     0     0  279   29  0  0 100  0  0
 0  0        0   794916     6828   103108    0    0     0     0  287   47  0  0 100  0  0
 0  0        0   794980     6828   103108    0    0     0     0  740   32  0  0 100  0  0
 0  0        0   794980     6828   103108    0    0     0     0  271   21  0  0 100  0  0
 0  0        0   794980     6828   103108    0    0     0     0  498   23  0  0 100  0  0
 0  0        0   794980     6828   103108    0    0     0     0  275   26  0  0 100  0  0
 0  0        0   794948     6828   103108    0    0     0     0  270   21  0  0 100  0  0
 0  0        0   794948     6828   103108    0    0     0     0  277   30  0  0 100  0  0
 1  0        0   794948     6828   103108    0    0     0     0  279   33  0  0 100  0  0
 0  0        0   794964     6828   103108    0    0     0     0  300   65  0  0 100  0  0
 0  0        0   794996     6828   103108    0    0     0     0  280   32  0  0 100  0  0
 4  0        0   794652     6828   103108    0    0     0     0  293  132  0  1 99  0  0
 1  0        0   710256     6828   103108    0    0     0     0  408   40 25  8 66  0  0
 1  0        0   624944     6828   103108    0    0     0     0 1186   14 23  2 75  0  0
 1  0        0   539136     6828   103108    0    0     0     0  364   15 24  1 75  0  0
 1  0        0   453452     6828   103108    0    0     0     0  768   15 24  1 75  0  0
 1  0        0   367396     6828   103108    0    0     0     0  365   14 24  1 75  0  0
 4  0        0   292840     6828   103108    0    0     0     0 1232   20 29  6 65  0  0
 4  0        0   286392     6828   103108    0    0     0     0  664   33 94  6  0  0  0
 4  0        0   286392     6828   103108    0    0     0     0  661   14 100  0  0  0  0
 4  0        0   286392     6828   103108    0    0     0     0  662   19 89 12  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  661   13 100  0  0  0  0
 5  0        0   286424     6828   103108    0    0     0     0  663   23 89 11  0  0  0
 4  0        0   286392     6828   103108    0    0     0     0  673   29 100  0  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  671   30 91  9  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  668   31 93  7  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  662   14 97  3  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  681   75 91  9  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  669   40 100  0  0  0  0
 4  0        0   286392     6828   103108    0    0     0     0  670   29 92  9  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  670   43 91  9  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  666   22 96  4  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  665   36 95  5  0  0  0
 4  0        0   286392     6828   103108    0    0     0     0  660   13 93  7  0  0  0
 4  0        0   286392     6828   103108    0    0     0     0  663   15 92  8  0  0  0
 4  0        0   286424     6828   103108    0    0     0     0  691  104 92  8  0  0  0
 4  0        0   286276     6828   103108    0    0     0     0  692   86 93  7  0  0  0
 4  0        0   286268     6828   103108    0    0     0     0  668   52 94  6  0  0  0
 4  0        0   286300     6828   103108    0    0     0     0  666   33 89 11  0  0  0
 4  0        0   286268     6828   103108    0    0     0     0  668   26 89 11  0  0  0
 4  0        0   286300     6828   103108    0    0     0     0  704  131 92  8  0  0  0
 4  0        0   286300     6828   103108    0    0     0     0  661   15 88 12  0  0  0
 1  0        0   286300     6828   103108    0    0     0     0 1435   59 72 21  7  0  0
 1  0        0   286268     6828   103108    0    0     0     0  365   14 25  0 75  0  0
 1  0        0   286300     6828   103108    0    0     0     0  371   17 25  0 75  0  0
 1  0        0   286268     6828   103108    0    0     0     0  388   37 25  0 75  0  0
 1  0        0   286300     6828   103108    0    0     0     0  370   16 25  0 75  0  0
 1  0        0   286300     6828   103108    0    0     0     0 1173   19 25  0 75  0  0
 0  0        0   795600     6828   103108    0    0     0     0  453   44 36  4 60  0  0
 0  0        0   795740     6828   103108    0    0     0     0  279   19  0  0 100  0  0
 0  0        0   795740     6828   103108    0    0     0     0  279   17  0  0 100  0  0
 0  0        0   795708     6828   103108    0    0     0     0 1082   11  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  284   30  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  272   19  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  269   19  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  277   25  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  274   24  0  0 100  0  0
 0  0        0   795684     6828   103108    0    0     0     0  297   50  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  278   31  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  273   23  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  689   27  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  271   22  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  486   27  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  272   21  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  717   23  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  274   26  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  276   27  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  275   30  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  276   29  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  277   30  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  269   20  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  725   22  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  273   22  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  270   23  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  494   21  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  270   22  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  272   24  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  280   34  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  278   29  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  275   26  0  0 100  0  0
 0  0        0   795732     6828   103108    0    0     0     0  274   22  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  271   23  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  271   21  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  271   22  0  0 100  0  0
 0  0        0   795700     6828   103108    0    0     0     0  732   21  0  0 100  0  0
^C
and the linpack
N      :    8000
NB     :     256
P      :       1
Q      :       1
PFACT  :    Left
NBMIN  :       2
NDIV   :       2
RFACT  :   Right
BCAST  :   2ring
DEPTH  :       0
U      : transposed form
EQUIL  : yes
WR02R2L2        8000   256     1     1              49.85              6.849e+00
HPL_pdgesv() start time Wed May 11 23:54:16 2016
HPL_pdgesv() end time   Wed May 11 23:55:05 2016
End of Tests.
dom
Wed May 11, 2016 10:10 pm
Rive wrote: So does this mean that the BT is causing the degradation? What about the sd_overclock? No good anymore in 4.4.9?
No, not BT directly. There are two uarts, either one can be used by BT, and the other can be used for serial output.
I think the problem is with an unused uart is being left with an interrupt asserted but no interrupt handler to clear it
(but the asserted interrupt does waste CPU). So that is not a problem and should be easy to fix.
The sdcard performance regression does appear to be from an upstream change.
Needs more investigation, but again I'd imagine it will be fixable.
dom
Wed May 11, 2016 10:11 pm
Gerd wrote:Well, there is no serial in interrupts
I suspect "dtoverlay=pi3-disable-bt" is also avoiding the issue. Remove that line and you'll probably hit the issue.
Rive
Wed May 11, 2016 10:14 pm
Good. Well glad I could help. So you don't need me anymore? Am I good to restore 4.1.19 until these issues are resolved?
DNPNWO
dom
Wed May 11, 2016 10:15 pm
Rive wrote:Good. Well glad I could help. So you don't need me anymore? Am I good to reinstall 4.1.19 until these issues are resolved?
Yes, thanks for the report. Feel free to switch back to 4.1.19, but hopefully there will be some fixes in the near future that we'll ask you to test.
Rive
Wed May 11, 2016 10:16 pm
Just let me know...Thanks
DNPNWO
Gerd
Wed May 11, 2016 10:29 pm
I am happy that the error could be narrowed down. At least my Pi could serve as a counterexample.
Wed May 11, 2016 10:45 pm
dom,
Report "vcgencmd get_throttled" output after doing some activity. If you get a non-zero result I can decode it.
$ vcgencmd get_throttled
error=1 error_msg="Command not registered"
What new firmware? This Pi 3 is all "apt-get ugraded".
Rive
Wed May 11, 2016 10:50 pm
Heater wrote:dom,
Maybe?
sudo rpi-update
DNPNWO
dom
Wed May 11, 2016 10:52 pm
Yes, rpi-update will get support (I assumed you'd have it in a thread about 4.4.9 kernel).
Or wait a few days for apt-get to be bumped.
Wed May 11, 2016 11:05 pm
$ sudo rpi-update
sudo: rpi-update: command not found
Wed May 11, 2016 11:18 pm
OK I got it:
$ sudo apt-get install rpi-update
$ sudo rpi-update
Crash during update !
Power cycle. Try again...
Change PSU. Try again...
Oddly, the ssh session freezes and I can not start another one, but the activity light still flickers.....
Rive
Wed May 11, 2016 11:21 pm
$ sudo rpi-update
No
Only this
sudo rpi-update
DNPNWO
Wed May 11, 2016 11:24 pm
Rive,
No...Only this...
But there was no such command as rpi-update on the machine.
Now there is.
Can't get it run with hanging the entire machine though, see above.
Rive
Wed May 11, 2016 11:30 pm
Heater wrote:Rive,
No...Only this...
Now there is.
Restore backup. I have never had to do a 'apt-get install rpi-update', only 'sudo rpi-update' .
Are we not both on Jessie, linux 4.1.13, pi3? I have no clue what you are doing. I didn't have to do that. :?
DNPNWO
Wed May 11, 2016 11:47 pm
Rive,
What I have here is a brand new Pi 3 with a brand new SD card.
I put Raspbian Lite on it. Version: March 2016 Release date:2016-03-18
Nothing else has been installed on it.
Presumably Lite does not have rpi-update out of the box.
I did do an apt upgrade so now I have :
$ uname -a
Linux raspberrypi3 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
Everything works, getting a million digits of Pi with gmp-chudnovsky for example.
rpi-update hangs consistently during download like so:
$ sudo rpi-update
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
 *** We're running for the first time
 *** Backing up files (this will take a few minutes)
 *** Remove old firmware backup
 *** Backing up firmware
 *** Remove old modules backup
 *** Backing up modules 4.1.19-v7+
WARNING: This update bumps to rpi-4.4.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=144087
Would you like to proceed? (y/N)
 *** Downloading specific firmware revision (this will take a few minutes)
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   168    0   168    0     0    291      0 --:--:-- --:--:-- --:--:--   292
 52 50.5M   52 26.5M    0     0   424k      0  0:02:01  0:01:03  0:00:58 2128k
