lilzz
How to run an user program on ESP8266 Wifi module
Tue May 10, 2016 7:30 pm
I don't want the original firmware changed.
I just want to run an user program (C code) after the system got booted up.
how to do that?
Re: How to run an user program on ESP8266 Wifi module
Tue May 10, 2016 7:40 pm
As far as I know you cannot.
At least not without reflashing it with some kind of bootloader/operating system that can download your compiled C code and run it. If there is such a thing.
You can reflash the thing to enable you to run your own Lua or Javascript code. For example Espruino: http://www.espruino.com/EspruinoESP8266
Google it.
Tue May 10, 2016 7:45 pm
Try posting your question on the ESP8266 forum. This one is for RASPBERRY PIs and not ESP8266s.
This might be a good starting point: http://randomnerdtutorials.com/tutorials-esp8266/
This is a doctor free zone.
Cancelor
Tue May 10, 2016 8:12 pm
I would recommend the Arduino IDE but it will wipe the ESP each time you load... no loss there ;-)
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
raspifriend
Wed May 11, 2016 10:54 am
use NodeMCU, ESP-Flasher and ESPlorer ... then you have a standalone
ESP-Module which can monitor digital inputs, control digital outputs and
the data can be easy accessed using the Web-Server which is part of
NodeMCU.
The script-language of NodeMCU is lua, but it is easy to learn. With
experience in perl, php or javascript the lua script language can be learned
within half an hour.
