Power off message?
Posted: Tue May 10, 2016 1:10 pm
by murmansk
I know that the Raspberry Pi has no power off switch. That you should shutdown your operating system, and only when shutdown has finished, you should turn off or disconnect your power adapter.
But we are using Raspbian with GUI, and when our users shutdown the OS, they only see a black screen.
There is any way of stoping processes, syncing the MicroSD, and show message in the GUI?. Something like "Now you can disconnect your power adapter".
Re: Power off message?
Posted: Tue May 10, 2016 2:14 pm
by Rive
I look at the led icons on Pi3, and power light on monitor.
Monitor light goes orange
LED's go solid red and solid green
Then I flip the power off switch on surge protector desktop strip that the monitor and Pi3 are plugged into.
Raspian Jessie GUI
Posted: Tue May 10, 2016 2:25 pm
by Dis93
Version 4.4.8 and later of the kernel (not included on the latest Jessie image, only if you run rpi-update) have changed the led behaviour to match that of earlier Pis.
After syncing, the green led will flash 10 times then switch off entirely to indicate clean shutdown.
Posted: Tue May 10, 2016 2:32 pm
by Rive
Word of warning...
If you plan to do
sudo rpi-update
Make sure you have a recovery backup ready ;) Because you may not be able to boot.
Posted: Tue May 10, 2016 3:41 pm
by Rive
Dis93 wrote:Version 4.4.8 and later of the kernel (not included on the latest Jessie image, only if you run rpi-update) have changed the led behaviour to match that of earlier Pis.
Yep the flashing green led, then off status is ok for determining "safe to power off" cue.
4.4.9 is current
I just did a rpi-update, no issues so far, and all the customization i did to the OS, seem to also be intact and unbroken.
All GUI changes are still in effect, Lockscreen, & Lockscreen keyboard binding capability, and the screensaver/screen blanking disablement all still functional, MOC (MP3 Player) and analog audio still functional...still checking the rest (OMXPLayer mod, Chromium 48, overclocks, etc).
[email protected]:~ $ cat /proc/version
Linux version 4.4.9-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #884 SMP Fri May 6 17:28:59 BST 2016
So far, So good.
