Dis93 wrote:Version 4.4.8 and later of the kernel (not included on the latest Jessie image, only if you run rpi-update) have changed the led behaviour to match that of earlier Pis.
After syncing, the green led will flash 10 times then switch off entirely to indicate clean shutdown.
Yep the flashing green led, then off status is ok for determining "safe to power off" cue.
4.4.9 is current
I just did a rpi-update, no issues so far, and all the customization i did to the OS, seem to also be intact and unbroken.
All GUI changes are still in effect, Lockscreen, & Lockscreen keyboard binding capability, and the screensaver/screen blanking disablement all still functional, MOC (MP3 Player) and analog audio still functional...still checking the rest (OMXPLayer mod, Chromium 48, overclocks, etc).
pi@raspberrypi:~ $ cat /proc/version
Linux version 4.4.9-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #884 SMP Fri May 6 17:28:59 BST 2016
So far, So good.
