First off, apologies if this is in the wrong place, wasnt sure if it belonged here or in the operating systems discussion board, and having read the rules, decided I think here is a better place for it.
Ok, what I really want to know is, is there a distro for the Pi, that will load quickly, and just let me run the one program i want to run, and then when its done, shut down? I might be able to put the shut down in my program closing.
Thing is, I am working on a project, where their is no screen and no input. Its literally going to start up, copy files from an inserted USBpen onto its built in memory (a self powered USB hard-drive probably) and shut down, or if no media is inserted, it'll just sit round and wait, because that'll mean that its being accessed over the network.
Oh, thats the other thing, the distro would need to support networked "folders"
Sorry for Using windows tearms, i'm used to windows, not linux
What Distro
dan3008 wrote:Pays your money, takes your choice
Re: What Distro
Linux is 100% flexible, so anything is doable, the question is with what amount of work, and in this case very little.
1) install raspbian (because it's the default, but any linux will do)
2) make your "auto copy" app (just use a service and a bash script)
3) make a smb/samba share (windows file sharing)
simple untested script example:
might want to add error checking to that etc.
use rsync if you want to update
or rsyncbackup if you want a "Time Machine" like tool
add as a service with "update-rc.d myscript defaults" and away you go
#!/bin/bash
PEN=/media/USB
LOOP=1
while [ $LOOP == 1 ]; do
DRIVES=$( ls -1 /dev/sd? | wc -l )
if [ $DRIVES -gt 1 ];then
mount $( ls -1 /dev/sd?1 | tail -n 1 ) $PEN
BPATH=/media/backups/backup-$(date +%Y%m%dT%H%M%SZ%z);
mkdir $BPATH
cp -r $PEN $BPATH
umount $PEN
LOOP =2
else
sleep 10
fi
done
shutdown -h now
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Re: What Distro
I thought rasbian had a login by default? or is that disable'able so it auto logs in?elatllat wrote:1) install raspbian (because it's the default, but any linux will do)
What language is best for doing that in you recon? I'm thinking i'm going to start learning python
- RaTTuS
- Contact: Twitter YouTube
Re: What Distro
see http://www.raspberrypi.org/phpBB3/viewt ... ab#p128375
should help
change the rtorrent to the script you want to run
should help
Covfefe
Covfefe
Re: What Distro
Running Puppy Linux here. It's been compiled with the Raspbian libraries. You can get it from http://bkhome.org/blog/?viewDetailed=02910
For more info poke around the puppy linux site. It's a small distro about 90 MB which has been ported to many architectures. In spite of size is pretty full featured.
I'm comparing it to Debian. One difference, browser is Chromium instead of Midori.
