jhfelectric
PCB Standoff
Mon May 09, 2016 10:31 am
I have been searching all around the web for standoffs or pillars compatible with the (not) mounting holes of the raspberry pi board.
The hole diameter being 2.9 mm, a 3 mm standoff will not fit, and smaller diameters seem to be not available.
To avoid misunderstanding with the wording, I am looking for Self-Adhesive Locking PCB Standoffs, such as these: http://www.ebay.co.uk/itm/PCB-Circuit-B ... 1419571487 but of course, of the correct dimensions !
Any body had any luck ? What other solutions would I have (cannot use screws in my situation) ?
Thank you for any help !
Burngate
Re: PCB Standoff
Mon May 09, 2016 4:29 pm
It's interesting how difficult it can be to find stuff on some websites.
I've just spent ten minutes looking at R S and Maplins - surely they'll have them? - with no luck. They're willing to sell me a plastic box, or hex pillars, or 4mm standoffs that latch in both ends, but not what I'm looking for. It's their search routine that's failing - R S, at least, used to sell them, cos 20 years ago we bought them, using their paper catalogue.
At least with the paper catalogue you could riffle through to the right page in 30 seconds - with the internet, it takes that long to get to the first wrong page, repeat for each of the next 30 wrong pages, then give up.
Rant over, have you thought of using a scalpel to make those you have fit? It's worked for me, at the expense of bleeding thumbs.
fruit-uk
Mon May 09, 2016 5:59 pm
Burngate wrote:At least with the paper catalogue you could riffle through to the right page in 30 seconds - with the internet, it takes that long to get to the first wrong page, repeat for each of the next 30 wrong pages, then give up.
Me too!
hippy
Re: PCB Standoff
Mon May 09, 2016 6:43 pm
jhfelectric wrote:The hole diameter being 2.9 mm, a 3 mm standoff will not fit
I haven't tried it with a Pi but, for PCB's I have had in the past where that's been a problem, I have used a circular file to enlarge the hole, filed the stand-off down, or done both.
fruit-uk
Mon May 09, 2016 8:02 pm
I know you said you cannot use screws but what about drilling through one of the self adhesive pads, countersinking the back then using a nylon countersunk set screw and spacers - which are available in smaller diameters
masa-aud
Re: PCB Standoff
Mon May 09, 2016 11:51 pm
This stad [p-01864] fits for my Pi, which screw diameter max = 2.7mm
http://akizukidenshi.com/catalog/goods/ ... rch.x=true
masa
navzptc
Re: PCB Standoff
Tue May 10, 2016 12:16 am
Drill out the holes to 3mm - No problems found with the ones I have done :)
texy
Re: PCB Standoff
Tue May 10, 2016 9:20 am
navzptc wrote:Drill out the holes to 3mm - No problems found with the ones I have done :)
+1
Texy
