ConradG13
SerLCD 1602
Sat May 07, 2016 3:42 pm
Ok, I need some help hooking a LCD up to the raspberry pi I have an image below of what it is. What pins would I put these on the GPIO on the raspberry pi 2?
Linksprite SerLCD 1602
People who say times instead of multiply shouldn't be around.
davidcoton
Re: SerLCD 1602
Sat May 07, 2016 4:02 pm
It's an Arduino (5V) compatible display. You'll need extra circuits to work with the Pi at 3V3, and possibly drivers that may or may not be available. Better to start with something designed for the Pi.
Signature retired
FTrevorGowen
Re: SerLCD 1602
Sat May 07, 2016 4:18 pm
FWIW, if you want/need a display (interface) that uses serial comns. then this backpack will do so and (in serial mode) does not need level-shifters between the Pi's 3.3V gpios and the the interface's (display's) 5V inputs etc.:
https://www.cpmspectrepi.uk/raspberry_p ... ackpack_V2
http://www.hobbytronics.co.uk/lcd/i2clcd-backpack-v2
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
ConradG13
Re: SerLCD 1602
Sat May 07, 2016 4:38 pm
Is there a way to make it so i do't use the controller, just the LCD, nothing else?
DirkS
Re: SerLCD 1602
Sat May 07, 2016 4:47 pm
ConradG13 wrote:Is there a way to make it so i do't use the controller, just the LCD, nothing else?
See e.g. http://www.raspberrypi-spy.co.uk/2012/0 ... ng-python/
FTrevorGowen
Re: SerLCD 1602
Sat May 07, 2016 4:53 pm
Or as I did here:
https://www.cpmspectrepi.uk/raspberry_p ... erial_Port
NB: level-shifters were in use.
Trev.
