MarkHaysHarris777 wrote:
You're in the minority...
How do you know? I doubt that a high percentage of owners of non-overheating Pi3s will report that fact, while it is probably a much higher proportion of owners of overheating Pi3s who report. Looking at reports is at best anecdotal evidence, at worst misleading.
The fairest summary at the moment is along these lines:
1) Some Pi3s overheat easily. Probably not a high proportion, but the actual figure is unknown (at least outside Sony/RS/Farnell/RPF).
2) Some Pi3s overheat under heavy loads. The number is almost certainly higher than in (1), and could be over 50%. However, many users may never push their Pi3 to the extent necessary to reveal this behaviour (if it occurs on their Pi3).
3) Some Pi3s seem to remain below throttling temperature even with heavy loads. Again, the actual figure is unknown, and could be more or less than (1). It could even be the majority.
4) No patterns have been established to identify Pi3s prone to overheating, other than by testing.
5) Pi3s which overheat with particular tasks can usually be kept cool by using appropriate heatsinks, aided by a fan if necessary. Fans are more likely to be necessary where natural convective airflow is restricted.
I am hoping that one day (soon?) we will have some objective quantified information to put the claims and opinion in context. I quite agree that, if your Pi3 overheats in your context, then the world is a nasty place and Something Should Be Done.
DISCLAIMER: The above summary is my opinion, formed by reading other published opinions. It is not backed by any scientific investigation of a sample of Pi3s greater than one, or by any reproducible methodology on that one. I can be wrong.
