Duhjoker
Crazy colored graphics in desktop raspbian after LCD install
Thu May 05, 2016 7:47 am
I've got super portable compact Pi 3 going and decided to install the LCD drivers.
I followed the waveshare wiki but now when it goes to desktop mode the colors are weird and the graphics aren't solid looking.
texy
Re: Crazy colored graphics in desktop raspbian after LCD ins
Thu May 05, 2016 8:41 am
Which model display? searching this forum brings up 771 instances of waveshare - maybe an answer is already available?
Texy
Duhjoker
Thu May 05, 2016 9:14 am
The 4 inch
Duhjoker
Thu May 05, 2016 8:56 pm
Its weird....... The screen only started doing this after the 2-18-2016 raspbian software release.
Duhjoker
Fri May 06, 2016 4:11 am
Any body have any clues?
I installed FBCP today and tried to startx but that doesn't work while fbcp is running. I've also tried my 3.5 inch screen and it gets the same issue.
Duhjoker
Sat May 07, 2016 7:31 pm
Really???!!!!
I cannot believe I'm the only person this has happened to. I could really use some help. I've googled my problem but I may not be using the right search terms.
Please help me!!!'
davidcoton
Sat May 07, 2016 8:55 pm
Power again? Same as your other thread?
Duhjoker
Sat May 07, 2016 10:23 pm
On the other stuff i believe your right but when i first started this thread some weeks ago i wasnt using the auxiliary battery supply i was using the micro USB with a brand new cable.
Besides it happens whether its getting juice from the micro-usb or the auxiliary power supply.
It actually started after the 02-18-16 raspbian jessie update.
davidcoton
Sat May 07, 2016 10:40 pm
I don't think you have taken in the fact that the Pi3 uses more power than the Pi2. Stuff that worked with the Pi2 might still give problems on the Pi3. Have you measured the 5V line voltage on the board? Is the power light flickering? Is your PSU and cable capable of 2.5A and maintaining 5V at the Pi? As I said before, don't waste time looking for other problems until you have eliminated power issues.
liz
Raspberry Pi Foundation Employee & Forum Moderator
Sun May 08, 2016 5:17 am
Reading your other thread - totally a power supply issue. PLEASE try a proper 2.5A supply and a proper cable before starting any more threads.
Director of Communications, Raspberry Pi
