lilzz
Installing a CP210x USB to Serial converter
Fri Apr 29, 2016 7:18 pm
dmesg | grep tty
usb 6-2: cp210x converter now attached to ttyUSB0
then I started Putty
Putty configuration
/dev/ttyUSB0 baud:9600
connect (open)
But it complains unable to open serial port.
B.Goode
Re: Installing a CP210x USB to Serial converter
Fri Apr 29, 2016 8:21 pm
Maybe the user account you are using does not have permission to access /dev/ttyUSB0 ?
scruss
Fri Apr 29, 2016 9:30 pm
Yes, that's most likely. I've used CP210s without problems, and your system looks like it is doing the happy thing.
Check for this:
$ groups
pi adm dialout cdrom sudo audio video plugdev games users netdev input indiecity
pi@rpi ~ $ ls -la /dev/ttyUSB0
crw-rw---T 1 root dialout 188, 0 Mar 28 11:45 /dev/ttyUSB0
You need to be part of the ‘dialout’ group to have read/write access to the serial port.
Pronouns: he/him
lilzz
Sat Apr 30, 2016 11:09 pm
well, I did
groups
lilzz adm sudo dip plugdev lpadmin
so, I added
useradd -G dialout lilzz
but it complains
useradd: user 'lilzz' already exists
lilzz
Sat Apr 30, 2016 11:17 pm
I can't add myself to dialout group.
sudo usermod -a -G dialout lilzz
then I check with groups
dialout still not there
scruss
Sun May 01, 2016 12:09 am
you need to log out and log back in again
Pronouns: he/him
lilzz
Sun May 01, 2016 8:36 pm
OK, my putty is finally launched now.
but it's a blank. it has a small green rectangular shape and nothing else.
I try to type in something but nothing shown.
scruss
Mon May 02, 2016 3:27 am
Is the device you're talking to really 9600 baud?
Have you crossed TX with RX, and vice versa, to make the null modem connection work?
Pronouns: he/him
lilzz
Mon May 02, 2016 7:45 pm
OK, I got something back like this.
But I can't type any command. What does this mean from the picture I shown? Is the communication OK? I attached a ESP8266 wifi module to the CP201x.
DirkS
Mon May 02, 2016 8:17 pm
lilzz wrote:I attached a ESP8266 wifi module to the CP201x.
Apparently the default rate may depend on the firmware version (although the ones I have all started off at 9k6)
Try higher speeds, up to 115k2.
Another thing to be aware of is that ESPs expect a CR+LF for entering commands. I'm not sure if Putty does this by default.
Mon May 02, 2016 8:31 pm
That sort of error usually means the baud rate is wrong.
lilzz
Wed May 04, 2016 9:22 am
Ok, I set the baud rate to 115200, I see something now.
but I type AT, and hit enter button.
I expect to see OK as response but nothing happened.
what's CR+LF? same as enter button?
DirkS
Wed May 04, 2016 9:45 am
lilzz wrote:what's CR+LF? same as enter button?
No, that depends on the system.
You will have to make Putty send both a carriage return and a linefeed when you hit enter.
IIRC There are settings in Putty about implied linefeed when sending, but I'm not 100% sure about that.
