asandford
Re: PiZero IoT HAT (bluetooth+wifi for $9)
Sat Aug 06, 2016 1:57 am
tweak42 wrote:Curious to see how it compares to the wifi on the Pi3 and any usb dongles. Did you get the external antenna?
I got the external antenna. I've done a quick test by using WinSCP to upload a large file. I got ~1.5 MB/s on an A+ with hat, 2-2.4MB/s on a 2B with hat, ~2MB/s on a Pi3 with hat (it disabled the internal wifi and both BT), and 2.5-3.5MB/s using the Pi3 onboard wifi. All tests used the same SDCard and onboard antennas (they were less than 6 feet away from the router).
alexeames
Sun Aug 07, 2016 7:28 am
It's now called pHAT :) (I'll edit the subject line of this thread to reflect the change). Good call guys! :D
Screen Shot 2016-08-07 at 09.20.15.png (684.39 KiB) Viewed 1117 times
Alex Eames RasPi.TV, RasP.iO
digger72
Re: PiZero IoT pHAT (bluetooth+wifi for $9)
Mon Sep 12, 2016 10:42 am
The pHAT is nice. The issue is that not every one is able to solder the 40 Pin Connector. The HubPiWi Blue is better alternative as it has 3 USB ports along with a WiFi and a Bluetooth. It does not require soldering the 40 Pin Connector. It makes connection through the Pogo Pins.
The kickstarter link to this project -https://www.kickstarter.com/projects/17 ... th-3-usb-p
treii28
Mon Sep 12, 2016 3:03 pm
I just picked one of these up and first thoughts:
First, it doesn't include a pass-through GPIO, so unless you get something like a pi-borg-2, you'll cut off your GPIO connectability for stacking hats.
Out of the box, wifi worked without a fuss. No such luck with the bluetooth. I went to their website and it said something about resetting the uart clock speed in the boot/config.txt so I did that - still no luck.
I checked that I had bluetooth support within the configured software, I did. Tried a few other basic things. Still no luck.
Posted to their support forum, four days passed with no responses.
As far as bluetooth+wifi usb dongles, I picked some up a cirago the $17 range that were recommended by another user on forums. They've worked fine on all my other pis.
